Author Topic: K7400 vs D9200 with ArcadeVGA  (Read 1952 times)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« on: March 16, 2004, 10:54:13 am »
I am starting my second cab.  Based on the rave reviews of the masses here, I will probably use an ArcadeVGA card.
Given the following facts:
*Windows GUI will not be used often if at all - only Mamewah or some other FE.
*25" vs 27" is not a differentiator for me
Is there any other benefit of the D9200 over the K7400?
Also, does anyone know how the power is supplied to the K7400?
Dave
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:K7400 vs D9200 with ArcadeVGA
« Reply #1 on: March 16, 2004, 07:34:20 pm »
I use an ArcadeVGA and a Wells Gardner 25k7191 standard res monitor.  Windows and windows games will probably look a lot better on the D9200 as they don't have to be run in interlaced mode (but you said you don't care about Windows games).
Hmmm...  I would assume that vector games like Asteroids, Tempest, and Star Wars would look better because you can run in a higher native resolution without interlacing.  Also, medium resolution games like 720 should look better because they won't need to be interlaced.
Note that I haven't seen a 9200 in action, but I know that these are limitations of the 7191.
I use a plug that I cut off of an extension cord which I attached to an isolation transformer which is then run to the monitor's power wires.
