Author Topic: Keyboard hack + Keyboard  (Read 2345 times)
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
« on: March 13, 2004, 10:01:13 am »
Hey,
I use a keyboard hack for my arcade controls, but the motherboard i have only takes a AT keyboard and the keyboard hack im using is a ps/2 keyboard so i just soldered it onto the board and it works fine, but the thing is i have also soldered on a normal keyboard aswell... i cant have them both working at the same time anyideas how i can?? Also, both the keyboard hack and keyboard allow me to detach the wire from them so i basically have to detach the wire from the keyboard hack to use the keyboard and detach the keyboard to use the keyboard hack.
I was wondering if there is a way to make them both work at the same time, or if putting a switch on the +5 on the keyboard to allow me to cut the power to that one instead of having to disconnect it.
Any help will be appreciated,
Nightmare
OSCAR
    • Oscar Controls
Re:Keyboard hack + Keyboard
« Reply #1 on: March 13, 2004, 10:12:12 am »
They can't be spliced directly together, as you have found out already.  A circuit was developed to allow simultaneous keyboards and can be found here:  http://home.t-online.de/home/stephan.hans/tricks.htm.
This link was found under the "Interfaces" heading right here on the BYOAC site.
SirPeale
  • Green Mountain Man
« Reply #2 on: March 13, 2004, 10:24:32 am »
You soldered it?  Why didn't you buy a $1.00 AT to PS/2 adaptor?
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« Reply #3 on: March 13, 2004, 10:33:58 am »
Here's Jay's Simpler Circuit.
I have built several keyboard splitters with my own variation of his AT design (PS2 as opposed to 5 pin Din).
It works great.
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
Zeitgeist
« Reply #4 on: March 13, 2004, 10:51:05 am »
Here's my adaptation of Jay's Splitter, redesigined for use with PS2 keyboards in case anyone is interested.
All you need is:
1 male 6 pin mini din plug (or cut a 6' PS2 extension cable)
2 female mini din plugs
1 4066 IC  (Quad Bilaterial Switch)
1 4093 IC (Dual NAND Trigger)
Some micro wire & a project board & box
BTW these can be daisy chained without any adverse effects.
Remember however that for a price there are two terrefic interfaces out there that will do a much better job than any old keyboard could.
With the blocking & ghosting issues and the time it takes to map out the matrix, keyboard hacks are hardly worth the trouble, unless you like the challlenge.
Just my 2 cents...
On the other hand I do have two stand alone panels that have hacks in them & work great except when all six buttons for both players are pressed simultaneously & both joystick are at a vertical.
Naturally they don't use the default MAME keystrokes.
Hope this helps.
Z
Nightmare03
  • Stupid llama!
« Reply #5 on: March 13, 2004, 11:23:32 am »
Thanks for the advice but i dont really wanna make a entire circuit... Is it possible to just cut off the +5v to the keyboard, thus cutting off its power and then disableing the keyboard?
RandyT
  • Last login:October 27, 2025, 02:12:45 pm
    • GroovyGameGear.com
« Reply #6 on: March 13, 2004, 06:34:55 pm »
All you need is a DPDT toggle switch and the 2 lines you need to switch are CLOCK and DATA.  Leave the GROUND and +5v hooked up for both devices.
RandyT
Nightmare03
  • Stupid llama!
« Reply #7 on: March 14, 2004, 07:23:21 am »
Thanks, ill give it a try later ;D
