Author Topic: Enabling mouse in Command Line Mame  (Read 7626 times)
killbill
  • Last login:March 03, 2026, 04:31:25 pm
  • When I die, I want to go to arcade heaven!
« on: March 12, 2004, 03:14:23 pm »
Hi,
I'm running Mame through Mamewah.  I'm trying to enable my mouse to play certain games like Centipede and Millipede.
How do I go about doing this?
Thanks.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:Enabling mouse in Command Line Mame
« Reply #1 on: March 12, 2004, 03:24:54 pm »
look in your mame.ini, there's an option that you can set to 1 (can't remember its name offhand).
killbill
« Reply #2 on: March 12, 2004, 03:43:12 pm »
Thanks.  I should have looked there.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #3 on: March 16, 2004, 09:48:31 pm »
If you are running in pure DOS, you may need a mouse driver.
killbill
« Reply #4 on: March 17, 2004, 04:15:52 pm »
Thanks, Stephen.
I'm running Command Line Mame through Windows XP.
Just changing the Mame.ini worked for me.
« Last Edit: March 17, 2004, 04:17:51 pm by killbill »
2600
« Reply #5 on: March 18, 2004, 09:27:06 am »
Why we are on the topic.  I've done this and my mouse works, but the mouse buttons do not.  For some reason, I was under the impression that for games like centipede the mouse buttons were also mapped to fire when the mouse is enabled.  Is this correct or do I need to configure it?
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: March 18, 2004, 09:58:01 am »
You need to configure it -
Either do the "Tab" key, "Input this Game" select "Button 1" and click the mouse button, or set it up in the ctrlr.ini files.
See http://www.mameworld.net/easyemu/mamecontrolini.htm if you didn't follow the last part.
2600
« Reply #7 on: March 18, 2004, 10:14:15 am »
Thanks, for some reason I recalled that for certain games the mouse button and button 1 were both configured as an input by default.
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: March 18, 2004, 10:53:18 am »
Actually, I just checked the std.ini ctrlr file that comes with MAME and it is supposed to be enabled.  Not sure if you don't have MAME set up to read this, or if MAME isn't recognizing your mouse buttons.
Post back if you have more problems.
2600
« Reply #9 on: March 19, 2004, 10:58:24 am »
Thanks Tiger-Heli you pointed me in the right spot.   For some reason it wasn't in my ini file, should of checked before I asked.
