Author Topic: HOW DO I SETUP THE COIN OPERATION?  (Read 1100 times)
marknetwork
  • Last login:December 08, 2011, 02:17:19 pm
  • arcade building can be frustrating...
    • MarkNetwork.com
« on: March 10, 2004, 12:19:36 pm »
Hello,
Do you guys know where I can get some sort of coin operation that can be setup with the x-arcade or right to the PC for my MAME arcade machine?  I plan on using MAME32 but I would really like to have it actually accept coins for fun.  What do most people do?
I'm using MAME32 and the X-arcade dual controller, and I'd like the arcade machine to accept coins instead of using a button...or maybe both whatever is easiest.  Any suggestions?
Thank you so much!
Mark
Great people talk about ideas; ordinary people talk about things; small-minded people talk about other people.
<a href="http://www.windowvideos.com">WINDOWVIDEOS.COM</a> - Ambient Video Experiences
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:HOW DO I SETUP THE COIN OPERATION?
« Reply #1 on: March 10, 2004, 12:23:09 pm »
marknetwork
    • MarkNetwork.com
« Reply #2 on: March 10, 2004, 12:28:59 pm »
Thanks I'll check it out now! :)
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« Reply #3 on: March 10, 2004, 03:19:01 pm »
Not sure if this will answer your question....
As long as you understand how a pushbutton/joystick works, using a coin door/box/whatever works the same; they all use microswitches connected to a keyboard encoder that translates the push of a pushbutton into a keyboard keystroke.
To re-iterate, when you push a button, or press a direction on a joystick, it basically is turned into a simple keyboard keystroke.   When you drop a coin in, it translates into a keystroke.
So, you just have to wire up the coin door microswitches to translate into keystrokes "1" and "2" since MAME uses these for coin inputs (via keyboard encoder which I think your xarcade has in it).
Hope I didn't misunderstand your question....
« Last Edit: March 10, 2004, 03:21:28 pm by alphasqorner »
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
marknetwork
    • MarkNetwork.com
« Reply #4 on: March 10, 2004, 03:33:08 pm »
I completely understand!!  Now I just have to find the wires....
Do you know where I could buy a complete coin kit or something so I dont have to find each piece by itself?  The one I have is too old and wrecked its not worth fixing.  What pieces do I need?
Thanks,
Mark
