Author Topic: Ms. Pac monitor hell continues.  (Read 2294 times)
Flashflood140
  • Last login:January 28, 2026, 04:02:01 pm
« on: November 09, 2025, 10:27:45 pm »
So I've made some progress on my Ms pacman with the 19in g07 I went and got a high voltage probe and tested the flyback.  No good. So i swapped back in the original flyback. I now have neck glow and flyback buzz. But I still don't have a picture! Monitor been recapped brand new neck board. I replaced the 902 fuse. What's next? Should I replace the the hot's
Sent from my SM-S921U1 using Tapatalk
Re: Ms. Pac monitor hell continues.
« Reply #1 on: November 17, 2025, 12:50:58 pm »
Go through this video step by step and follow along.  He tests all the components.  That should get you up and running:
https://youtu.be/VPMf2mIa4k4?si=MGcQlzoe5TiddXlk
Del
Flashflood140
« Reply #2 on: November 29, 2025, 09:22:54 pm »
Im still having issues does anyone know if this is good neck glow went ahead replaced a couple of resistors on the chassis r123 r122 which I think are for the heater circuit. Does anyone know what the resistor is for r 122? The rebuild video didn't help as I'm not rebuilding this chassis just trying to get it working. Anyway to find out if the tube is okay?
Flashflood140
« Reply #3 on: January 11, 2026, 04:36:59 am »
Okay I pulled the shut down transistor.  And it fired right up literally. Something went up in smoke i have no idea what is causing these issues it's driving me mad.
Sent from my SM-S938U using Tapatalk
