Author Topic: help with Teknoparrot and Logitech g920 loosing configuration....  (Read 559 times)
Arcee360
  • Last login:November 20, 2025, 12:33:28 pm
  I have some cabinets with Teknoparrot installed. I have them networked and everything working good except whenever I exit a game and go back in, or into a different game the controls are unresponsive. So I will exit again and check the control assignments which are all still intact in setup. I will then have to go thru the reconfiguring of the contols and then go into the game for it to work. This is on all the cabinets. Desperate for help if anyone knows whats going on. Thank You
buttersoft
  • Last login:Today at 04:56:05 am
  • Is running at 15kHz
Re: help with Teknoparrot and Logitech g920 loosing configuration....
« Reply #1 on: October 30, 2025, 06:54:26 pm »
Same problem on both PCs? Something set to read-only, maybe? Xinput set in TP rather than Dinput?
What happens if, instead of rebinding, you reboot a machine?
