Author Topic: 3d Printed Star Wars Yoke Mounts -- Countersunk and Standalone  (Read 12668 times)
  • Last login:Today at 04:23:32 am
Here's a v1.0 OpenSCAD model for a panel mount countersunk SW yoke mount with a drill/cutout template.
- The base is 180mm wide x 200mm deep and the mount is 115mm tall.
- The mount is high enough that when the front housing of the yoke is turned 45 degrees, it will still clear the control panel.
- The gears only stick out about 1.5" below the mount.
- This version is a fixed 45 degree angle.  I could remix it into a variable angle version if there's any interest.
- Use 1/4"-20 x 1-1/2" carriage bolts for mounting hardware.
// SW Yoke Countersunk Mount for Alan-1 yoke v1.0.
//  Define the variables
    // Housing variables
RoundoverDia = 10; // Edge roundover diameter
SideThick = 3.2; // Side thickness
VertZ = 15; // Vertical front/back panel height
HousingX = 140; // Housing width
HousingY = 200; // Housing depth
HousingZ = VertZ + (HousingY/2); // Overall housing height
MountOffsetY = 70; // Mount distance from front edge
BaseX = 180;  // Overall base width
BaseY = 200;  // Overall base depth
BaseZ = 6;    // Overall base height
BaseBolt = 7; // Base carriage bolt hole size
BaseBoltInset = 10; // Base carriage bolt hole inset distance
// Number of fragments (polygon sides) used to render a full circle.
    $fn = 180; // Default = 180  Typical range = 6 - 360
    // 6 will render a circular hole as a hexagon, 8 will render a circular hole as an octagon.
    // Lower the number for faster rendering, raise the number for smoother rendering.
// Define modules
module FlangeHoles(){ //
    translate([BaseBoltInset, BaseBoltInset, BaseZ/2])
    cube ([BaseBolt, BaseBolt, BaseZ + 0.1], center=true); // Front left flange carriage bolt hole
    translate([BaseX - BaseBoltInset, BaseBoltInset, BaseZ/2])
    cube ([BaseBolt, BaseBolt, BaseZ + 0.1], center=true); // Front right flange carriage bolt hole
    translate([BaseX - BaseBoltInset, BaseY - BaseBoltInset, BaseZ/2])
    cube ([BaseBolt, BaseBolt, BaseZ + 0.1], center=true); // Back right flange carriage bolt hole
    translate([BaseBoltInset, BaseY - BaseBoltInset, BaseZ/2])
    cube ([BaseBolt, BaseBolt, BaseZ + 0.1], center=true); // Back left flange carriage bolt hole
module YokeMount(){ //Yoke mount module -- 76x90 main hole, 90x90 8mm screw holes
    translate([BaseX/2, RoundoverDia/2, VertZ])
    rotate([45, 0, 0])
    translate([0, MountOffsetY, 0])
    cube ([76, 90, SideThick*4], center=true);// 76x90 main hole
    rotate([45, 0, 0])
    translate([0, MountOffsetY, 1])
    translate([-45, 45, 0])
    cylinder (SideThick*4, d = 8, center=true); // Yoke screw hole 1
    rotate([45, 0, 0])
    translate([45, 45, 0])
    cylinder (SideThick*4, d = 8, center=true); // Yoke screw hole 2
    rotate([45, 0, 0])
    translate([45, -45, 0])
    cylinder (SideThick*4, d = 8, center=true); // Yoke screw hole 3
    rotate([45, 0, 0])
    translate([-45, -45, 0])
    cylinder (SideThick*4, d = 8, center=true); // Yoke screw hole 4
} // End YokeMount module
module DrillTemplate(){ // Drill template module
    difference(){ // Drill plate minus carriage bolt holes and yoke mechanism hole
        hull (){ // Drill plate hull
            translate([BaseZ/2, BaseZ/2, 1])
            cylinder (2, d = BaseZ, center=true);
        // Front left base
            translate([BaseX - BaseZ/2, BaseZ/2, 1])
        // Front right base
            translate([BaseX - BaseZ/2, HousingY - BaseZ/2, 1])
        // Back right base
            translate([BaseZ/2, HousingY - BaseZ/2, 1])
        // Back left base
        } // End Drill plate hull
        FlangeHoles(); // Carriage bolt holes
        translate([BaseX/2 + 14.5, RoundoverDia/2, VertZ])
        rotate([45, 0, 0])
        translate([0, MountOffsetY, -70])
        cube ([105, 70, 150], center=true); // Yoke mechanism hole
        translate([BaseX/2, 20, 1])
        Label("Player");  // Call the label module for Player
    } // End drill plate minus carriage bolt holes and yoke mechanism hole
} // End Drill Template module
module Label(letter, size=12) {
        rotate ([0, 0, 0]) {
            color("black")
            linear_extrude(height=1 + 0.01, convexity=4)
                text(letter,
                     size=size*22/30,
                     font="Bitstream Vera Sans",
                     halign="center",
                     valign="center");
} // End Label module
//  Make the part
translate([-BaseX - 30, 0, 0])
DrillTemplate(); // Make drill template
difference (){ // Difference of union of base flange and housing outer hull minus housing inner hull, yoke mount, and carriage bolt holes
    union (){ // Union base flange and housing outer hull
        hull (){ // Base flange hull
        // Front left base
        // Front right base
        // Back right base
        // Back left base
            translate([BaseZ/2, BaseZ/2, BaseZ/2])
            sphere (d=BaseZ);
        // Front left middle
            translate([BaseX - BaseZ/2, BaseZ/2, BaseZ/2])
            sphere (d=BaseZ);
        // Front right middle
            translate([BaseX - BaseZ/2, HousingY - BaseZ/2, BaseZ/2])
            sphere (d=BaseZ);
        // Back right middle
            translate([BaseZ/2, HousingY - BaseZ/2, BaseZ/2])
            sphere (d=BaseZ);
        // Back left middle
        } // End base flange hull
        hull (){ // Housing outer hull
            translate([BaseX/2 - HousingX/2 + RoundoverDia/2, RoundoverDia/2, 1])
            cylinder (2, d = RoundoverDia, center=true);
        // Front left base
            translate([BaseX/2 + HousingX/2 - RoundoverDia/2, RoundoverDia/2, 1])
        // Front right base
            translate([BaseX/2 + HousingX/2 - RoundoverDia/2, HousingY - RoundoverDia/2, 1])
        // Back right base
            translate([BaseX/2 - HousingX/2 + RoundoverDia/2, HousingY - RoundoverDia/2, 1])
        // Back left base
            translate([BaseX/2 - HousingX/2 + RoundoverDia/2, RoundoverDia/2, VertZ])
            sphere (d=RoundoverDia);
            translate([BaseX/2 + HousingX/2 - RoundoverDia/2, RoundoverDia/2, VertZ])
            translate([BaseX/2 + HousingX/2 - RoundoverDia/2, HousingY - RoundoverDia/2, VertZ])
            translate([BaseX/2 - HousingX/2 + RoundoverDia/2, HousingY - RoundoverDia/2, VertZ])
        // Back left middle
            translate([BaseX/2 - HousingX/2 + RoundoverDia/2, HousingY/2, HousingZ - RoundoverDia/2])
        // Top left
            translate([BaseX/2 + HousingX/2 - RoundoverDia/2, HousingY/2, HousingZ - RoundoverDia/2])
        // Top right
        } // End housing outer hull
    } // End union base flange and housing outer hull
    hull (){ // Housing inner hull
        translate([BaseX/2 - HousingX/2 + RoundoverDia/2, RoundoverDia/2, 0.9])
        cylinder (2, d = RoundoverDia - (SideThick * 2), center=true);
        // Front left base
        translate([BaseX/2 + HousingX/2 - RoundoverDia/2, RoundoverDia/2, 0.9])
        // Front right base
        translate([BaseX/2 + HousingX/2 - RoundoverDia/2, HousingY - RoundoverDia/2, 0.9])
        // Back right base
        translate([BaseX/2 - HousingX/2 + RoundoverDia/2, HousingY - RoundoverDia/2, 0.9])
        // Back left base
        sphere (d=RoundoverDia - (SideThick * 2));
        // Back left middle
        // Top left
        // Top right
    } // End housing inner hull
    YokeMount(); // Yoke mount
    FlangeHoles(); // Base flange carriage bolt holes
} // End difference of union of base flange and housing outer hull minus housing inner hull, yoke mount, and carriage bolt holes
// Test cube yoke mechanism 76x90x150
rotate([45, 0, 0])
color("red")
*cube ([76, 90, 151], center=true);
// Test cube mount plate footprint
Clearance = 0; // Offset to check clearance for yoke front housing rotation. 0 = yoke centered.  30 = yoke turned 45 degrees)
rotate([45, 0, 0])
translate([0, MountOffsetY - Clearance, RoundoverDia/2-0.2])
color("blue")
*cube ([120, 120, 02.01], center=true);
// Test carriage bolt cylinder
color("white")
*cylinder (BaseZ + 4, d = (14.4), center=true);
When assembling the mount, connect the yoke to the mount then connect the mount to the panel.
Download link for OpenSCAD and .STL files:
Countersunk v1.0 - https://forum.arcadecontrols.com/index.php?action=dlattach;topic=164992.0;attach=397959
Countersunk v1.1 - https://forum.arcadecontrols.com/index.php?action=dlattach;topic=164992.0;attach=397964
The standalone version is almost done.  Will post it after doing a test print.
EDIT: Updated D/L link.
« Last Edit: August 20, 2025, 05:27:18 pm by PL1 »
Re: 3d Printed Star Wars Yoke Mounts -- Countersunk and Standalone
« Reply #1 on: August 20, 2025, 05:23:22 pm »
Updated Countersunk Mount to v1.1 -- The .zip file contains the OpenSCAD files for 45 and 25 degree mounts/drill templates and .STL files.
https://forum.arcadecontrols.com/index.php?action=dlattach;topic=164992.0;attach=397964.
- Fixed several minor code errors.
- Added variable "BaseBoltInsetY" to move the carriage bolt holes closer to the center of the mount's Y-axis.
- Added variable "MountAngle" for the yoke mount.  Default is 45 degrees minus the angle of the control panel.
- Made a 25 degree version for Telengard since he has a steep 20 degree pitch on his control panel. (45-20=25)
Countersunk Mount v 1.1:
// SW Yoke Countersunk Mount for Star Wars or Alan-1 yoke v1.1.
// Use the template to drill holes one at a time.  Put a 1/4"-20 carriage bolt into each hole after you drill it to ensure proper alignment.  After all four holes are drilled, cut the hole for the yoke mechanism.
// Attach the yoke to the mount then use 1/4"-20 x 1-1/2" carriage bolts to attach the mount to the control panel.
MountAngle = 45;    // Angle of the face where the yoke is attached -- usually 45 minus the angle of the control panel
BaseZ = 4;          // Base flange thickness
BaseBoltInset = 10; // Base carriage bolt hole inset distance from corner
BaseBoltInsetY = 0; // Base carriage bolt hole additional Y-axis inset distance (moves holes closer to center)
// Define modules
    translate([BaseBoltInset, BaseBoltInset + BaseBoltInsetY, BaseZ/2])
    translate([BaseX - BaseBoltInset, BaseBoltInset + BaseBoltInsetY, BaseZ/2])
    translate([BaseX - BaseBoltInset, HousingY - BaseBoltInset - BaseBoltInsetY, BaseZ/2])
    translate([BaseBoltInset, HousingY - BaseBoltInset - BaseBoltInsetY, BaseZ/2])
    rotate([MountAngle, 0, 0])
    difference(){ // Drill plate minus carriage bolt holes, yoke mechanism hole, and player label
        // Front left drill plate corner
        // Front right drill plate corner
        // Back right drill plate corner
        // Back left drill plate corner
        } // End drill plate hull
        FlangeHoles(); // Drill plate carriage bolt holes
        cube ([105, 70, 150], center=true); // Drill plate yoke mechanism hole
        Label("Player");  // Call the label module for Player on the drill plate
    } // End drill plate minus carriage bolt holes, yoke mechanism hole, and player label
            color("black")
                text(letter,
                     size=size*22/30,
                     halign="center",
                     valign="center");
//  Make the part
            // Front left base
            // Front right base
            // Back right base
            // Back left base
            sphere (d=BaseZ);
            // Front left middle base
            sphere (d=BaseZ);
            // Front right middle base
            sphere (d=BaseZ);
            // Back right middle base
            sphere (d=BaseZ);
            // Back left middle base
            // Front left base outer
            // Front right base outer
            // Back right base outer
            // Back left base outer
            // Front left middle outer
            // Front right middle outer
            // Back right middle outer
            // Back left middle outer
            translate([0, 135, 0])
            // Top left outer
            // Top right outer
        // Front left base inner
        // Front right base inner
        // Back right base inner
        // Back left base inner
        // Front left middle inner
        // Front right middle inner
        // Back right middle inner
        // Back left middle inner
        // Top left inner
        // Top right inner
color("red")
color("blue")
*cube ([120, 120, 2.01], center=true);
translate([BaseBoltInset, BaseBoltInset + BaseBoltInsetY, BaseZ])
color("white")
*cylinder (6, d = (14.4), center=true);
Telengard 25 degree version with shorter Y-axis (200==>165mm) and closer carriage bolts (180==>115mm center-to-center):
HousingY = 165;     // Housing depth
MountAngle = 25;    // Angle of the face where the yoke is attached -- usually 45 minus the angle of the control panel
BaseBoltInsetY = 15; // Base carriage bolt hole additional Y-axis inset distance (moves holes closer to center)
// Define modules
            color("black")
                text(letter,
                     size=size*22/30,
                     halign="center",
                     valign="center");
//  Make the part
            // Front left base
            // Front right base
            // Back right base
            // Back left base
            sphere (d=BaseZ);
            sphere (d=BaseZ);
            sphere (d=BaseZ);
            sphere (d=BaseZ);
            // Top left outer
            // Top right outer
        // Top left inner
        // Top right inner
color("red")
color("blue")
color("white")
25 degree mount:
25 degree test print currently in progress.
« Reply #2 on: August 22, 2025, 01:47:41 am »
25 degree test print worked great.
- Perfect fit.
- Gears/wiring only sticks out about 3.5" below the mount.
A question came up via PM about calculating the mount angle on a tilted control panel.
- Red plus yellow equals orange.
- Yellow is the variable "MountAngle" in the OpenSCAD code.
« Reply #3 on: August 24, 2025, 11:59:26 pm »
Yoke and 25 degree test print mounted on scrap 1/2" plywood using 1/4"-20 x 1-1/2" carriage bolts.
« Reply #4 on: October 21, 2025, 05:22:55 pm »
Telengard used the countersunk mount on his cab with swappable panels.
He says that the template makes the jigsaw cuts easy and the mount works great.
Pic posted with his permission.
Locke141
  • Never grow up.
« Reply #5 on: November 09, 2025, 01:45:59 pm »
Nice
« Reply #6 on: November 09, 2025, 06:28:58 pm »
Thanks.   :cheers:
