Author Topic: IPAC-2 +Pac-Link +Sanwa joystick and buttons +Xbox 360?  (Read 2690 times)
iRunfast
  • Last login:September 04, 2025, 04:43:01 am
« on: August 13, 2025, 06:16:11 am »
Hi,
First time here :)
Need help with controls.
My setup;
1 player arcade cab with 1 joystick and six player buttons (all Sanwa) + 10 extra/available buttons. (Built the cab myself).
32” lcd monitor in Tate mode
Xbox 360 RGH 3.0 only running Tate schmups
I-PAC-2 (2015)
Pac-Link
Is it possible to get this setup to work, I mean is it possible to control/play the 360 via the Sanwa controls?
Where do i start?
Regards
Robert
Sweden
nugarp
  • Last login:January 26, 2026, 09:25:32 pm
Re: IPAC-2 +Pac-Link +Sanwa joystick and buttons +Xbox 360?
« Reply #1 on: August 14, 2025, 11:39:46 pm »
I did this a while ago. I had used a RS232-input KVM to swap the monitor input to the x360 and a ton of relays to redirect the output from the happ buttons to a soldered 360 pad instead of my ipac2. That was 11 years ago. Now, most xbox 360 tates are on steam and/or Xenia is far enough along that you may not need that 360 at all anymore. If I were to do it again, I would consider steam + xenia, and ditch the 360 completely. It will simplify things A LOT.
See here: https://forum.arcadecontrols.com/index.php/topic,138229.msg1434833.html#msg1434833
« Last Edit: August 14, 2025, 11:43:41 pm by nugarp »
iRunfast
« Reply #2 on: August 21, 2025, 08:47:35 am »
Well well, i think ill follow youre advice then.
Thank you nugarp  :applaud:
