Author Topic: [SOLVED] Switchres is disabled  (Read 4099 times)
Nodoyuna
  • Last login:November 29, 2025, 11:48:41 am
« on: May 04, 2025, 07:25:15 pm »
Hi
Starting with GroovyMAME latest version, when I run a game, in the info screen it says the message "Switchres is disable"
This is happening to all games
Am I missing something? It worked fine in previous versions
Thanks in advance
« Last Edit: May 05, 2025, 02:59:42 am by Nodoyuna »
Nodoyuna
Re: [SOLVED] Switchres is disabled
« Reply #1 on: May 05, 2025, 03:00:28 am »
It seems I've been able to solve the problem myself  8)
wamaauto
  • Last login:May 12, 2025, 10:17:41 pm
« Reply #2 on: May 12, 2025, 10:17:41 pm »
It seems I've been able to solve the problem myself wama  8)
Wow, I’m really glad to hear you managed to solve your problem! If you don’t mind, could you share how you did it? It might help others who run into the same issue.
