Author Topic: Carnevil stuttering sound  (Read 12766 times)
purbeast
  • Last login:January 03, 2026, 01:02:11 pm
« on: April 06, 2025, 03:51:09 pm »
Initially I had the issue where the game did not run at the right speed, but I saw the fix for that on here by I think setting autosync to 0 in a custom ini file, which solved the game speed issue.
However while the game plays at the right speed, I am getting random sound stuttering.  It's not a constant thing either it appears to be quite random.  Sometimes the clown dude will stutter like 1x or 2x when loading up the haunted house level.  Then when I start shooting those enemies you can definitely notice some more stuttering there as well.
I own an actual Carnevil PCB so I know what it should sound like and yeah, it's definitely not quite right.
I have searched on this but haven't come across anyone else having this issue so it makes me wonder.  I am using GroovyMAME .237 if I remember correctly.
Any ideas how I can fix this?
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
purbeast
Re: Carnevil stuttering sound
« Reply #2 on: April 17, 2025, 07:35:59 am »
I'm confused what in that link you are really referring to.
That thread is referring to the game speed running too fast.
haynor666
  • retro maniac
« Reply #3 on: April 17, 2025, 10:19:17 am »
Exactly, We had problems with Midway 3D games but Calamity found solution for strange speed and sound stuttering. Just get latest groovymame and re-create default configuration. With recommended groovymame settings game should work fine now.
purbeast
« Reply #4 on: April 17, 2025, 12:19:12 pm »
Okay great, I will try that out when I have time to get around to it.
purbeast
« Reply #5 on: April 25, 2025, 11:11:31 am »
So I just upgraded to .276 this morning and I am still seeing the same stuttering sound issues unfortunately.
Any ideas on the specific settings that may need to be set for this game?
EDIT:
I tried setting these from a post of yours from a while back, so that's what I currently have.
waitvsync 1
sync_mode 0
refreshspeed 0
syncrefresh 0
throttle 1
Changing waitvsync setting from 0/1 is noticeable as far as screen tearing goes in this game.
Do you think this could potentially be a hardware issue?  i'm running like 10 year old hardware basically, and one of my RAM slots on the motherboard is busted so I only have 8gb of ram in there instead of the 16gb that I actually have.
« Last Edit: April 25, 2025, 11:19:29 am by purbeast »
haynor666
  • retro maniac
« Reply #6 on: April 26, 2025, 03:54:23 am »
Seattle driver is very demanding. Carnevil runs in game from 250 to 300 % speed on 10600KF on stock MAME.
purbeast
« Reply #7 on: April 26, 2025, 09:16:08 am »
Ah okay.  Then yeah probably a hardware issue. My buddy is giving me an i7 and 32gb of RAM.  Right now I am on an i3 so I am guessing this will resolve that problem.
haynor666
  • retro maniac
« Reply #8 on: May 04, 2025, 06:11:34 am »
Pay attention to single core score rather than generation or class. I think most games still uses single core for emulation. In many case most recent core i3 (12100 or 13100) will be enough.
purbeast
« Reply #9 on: May 27, 2025, 02:53:59 pm »
I ended up getting an i7 6700k from my buddy with 32gb of RAM, and it runs Carnevil without any stutters.
Time Crisis 2 however still runs slow and from what I've seen, it's working more recently and needs a higher end CPU to work.  I'm hoping it gets some work and gets optimized at some point but not holding my breathe.
haynor666
  • retro maniac
« Reply #10 on: July 06, 2025, 04:04:31 am »
NamcoS23 driver is currently marked as not working (though You can play game as I can see). Still on 10600KF speed drops to 88% in Time Crisis II. Some games barely gets 40%.
« Last Edit: July 06, 2025, 04:06:13 am by haynor666 »
Endprodukt
  • Last login:Yesterday at 03:44:20 pm
« Reply #11 on: July 09, 2025, 06:13:09 am »
100% on overclocked 13600k.
haynor666
  • retro maniac
« Last Edit: July 09, 2025, 10:35:14 am by haynor666 »
Endprodukt
« Reply #13 on: July 10, 2025, 08:12:27 am »
If this cpu can't play it, the game needs optimization. This is why I bought the CPU haha
haynor666
  • retro maniac
« Reply #14 on: July 15, 2025, 03:02:54 pm »
On my arcade PC I have 14100F. I wonder how will work on this processor.
EDIT. Time Crisis II stil works slow even on this processor.
« Last Edit: July 15, 2025, 03:10:26 pm by haynor666 »
