Author Topic: partial vertical collapse  (Read 3250 times)
doeby
  • Last login:July 27, 2025, 11:58:40 pm
« on: March 24, 2025, 11:13:20 am »
i have an ivan off road racing{WG}, sent the board away for repair.  i then took monitor out of cab and the chassis.
I got the board back, as i was putting it back together the neck board was real pain to get back together with monitor.
Now i have half a good screen, and top half of screen has vertical collapse.  i have all the colors and good focus on the working part.
the screened was flipped and backwards, so i flipped the red and the blue, and the screen wasn't backwards anymore
then i flipped the green and yellow, and now have total collapse.
Is it definitely the chassis has a problem?
Could this happen if i messed pins up putting the yoke back on?
I am correct in saying this problem is not the main board since its vertical collapse?
The monitor did work before i sent the board away for repair.
« Last Edit: March 24, 2025, 05:00:28 pm by doeby »
Zebidee
  • Last login:February 16, 2026, 01:21:22 pm
Re: partial vertical collapse
« Reply #1 on: March 24, 2025, 07:46:07 pm »
You get a horizontal line on the screen?
CRT chassis might be just some cold/dry/cracked solder joins, opened up due to being handled and moved about, and most likely around the vertical IC. Check underside carefully with a magnifier lens, reflow solder if necessary.
Could also be caps (have they ever been checked/replaced?) or the vertical IC itself. Try checking voltages at Vcc, input & output pins.
You can send the monitor chassis (sans tube) away for repair too, so long as they have a compatible tube to test it on.
