Author Topic: Using Dibond for the console of a diy cabinet  (Read 2227 times)
zatarra76
  • Last login:March 22, 2025, 10:04:00 am
« on: March 22, 2025, 10:04:00 am »
Hello,
someone has never used dibond (two thin plate s of aluminum and plastic material inside) as a console for snapon buttons?
I was wondering if it's hard enough to handle buttons and joysticks.
Let me know your experiences.
Zebidee
  • Last login:February 18, 2026, 09:18:11 pm
Re: Using Dibond for the console of a diy cabinet
« Reply #1 on: March 22, 2025, 12:46:43 pm »
I suggest 2mm steel sheet. Sketch out your design and find a local metal working shop. They should be able to cut and bend the sheet in one plane (direction). Drill holes yourself. Cheaper than you probably think, you could probably get multiple blanks for small extra cost. New tariffs will make it a bit more expensive in some places.
Cut steel edges can be a bit sharp so take care and round them off with a metal file and some sandpaper.
