Author Topic: Warning sign on my display adapter after installing CRTEMUDRIVER  (Read 3736 times)
Elaphe666
  • Last login:August 13, 2025, 05:28:12 pm
Is it normal that my display adapter on the device manager shows a warning sign indicating some kind of problem?
Do I have to leave Windows as testsigning off or on? I had to run bcdedit.exe -set testsigning on after installing CRTEMUDRIVER because it was never on after running the install program, but that didnt't work either and then I found out that I had to disable a security setting in my bios, which finally made it.
Zebidee
  • Last login:Today at 08:02:20 pm
Re: Warning sign on my display adapter after installing CRTEMUDRIVER
« Reply #1 on: January 25, 2025, 01:15:58 am »
You must restart after installing the driver to get test mode on.
There will be a message at bottom-right. Can't remove the message, but is possible to change it if it really bothers you.
Elaphe666
« Reply #2 on: January 25, 2025, 03:29:22 am »
I know. What I was asking was if that testsigning mode (indicated by the message you mention) should be left permanently on after the drivers have been installed. I will try enabling it today and see if the warning on the device manager is gone. If I can't fix that, I will try uninstalling the drivers and installing them again. Before installing the CRTEMUDRIVER I had the official AMD driver for my 7750 installed and without any warning.
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #3 on: January 25, 2025, 06:42:15 am »
If I remember correctly test mode must pernament. But there is a program that can remove test mode watermark.
« Last Edit: January 25, 2025, 11:22:22 am by haynor666 »
Zebidee
« Reply #4 on: January 25, 2025, 11:00:45 am »
Yes
