Author Topic: Atari Tempest spinner pinout sanity check for USB hack  (Read 3198 times)
alfonzotan
  • Last login:August 10, 2025, 04:06:03 pm
    • The Cab With No Name
« on: October 08, 2024, 05:30:49 pm »
Working on a little hack for my multi-vector cab that I've done multiple times in the past, but can't get working now for some random reason:  taking an old ball mouse and rewiring it to act as a USB interface for an optical board, in this case a Tempest spinner.  I've tried two different mouse boards and can't get any screen motion on a PC, a Mac or a Pi.  I know the optical board works, the spinner tests fine in my actual Tempest cabinet, and I know the mice (mouses?) worked, they both tested working as well.
Looking at the schematic and the board, I think I've got this right, but I can't get any computer to recognize it.  Please have pity and sanity-check me:
  • Last login:Today at 05:35:55 pm
Re: Atari Tempest spinner pinout sanity check for USB hack
« Reply #1 on: October 09, 2024, 03:52:33 am »
To confirm that you have the pin numbers right, apply power to the board and use your phone camera to see if the IR LEDs light.
- If they light, the pin numbers are right because the LEDs are forward biased.
- If they don't light, the pin numbers are backward because the LEDs are reverse biased.
If the LEDs light but you get no movement when you block/unblock the optos, you may have an active-high opto board and an active-low mouse encoder. (or vice-versa)
- What voltages do you get for logic HIGH and LOW?
alfonzotan
« Reply #2 on: October 09, 2024, 01:53:00 pm »
Thank you, looks like this one is active high.  No wonder it wasn't working.
    • GroovyGameGear.com
« Reply #3 on: October 10, 2024, 11:19:18 am »
The schematic suggests that the outputs need to be pulled low externally.  Whatever you are connecting to it, may not be doing this, or doing it in such a way that the waveform isn't readable by that device.  That's my thought anyway.
alfonzotan
« Reply #4 on: October 10, 2024, 01:41:05 pm »
alfonzotan
« Reply #5 on: October 15, 2024, 05:23:51 pm »
Rather than keep fighting with this setup, I just sprung for an Opti-Pac, set P1 Spinner X to active high with the little utility application, and boom, it works.
Yes, I probably could have found a cheaper fix...
