Author Topic: hp elitedesk 705 g4 2400g crt emudriver setup  (Read 2328 times)
freakmin
  • Last login:October 06, 2024, 12:44:58 pm
« on: September 21, 2024, 08:07:36 am »
I already have a working CRT setup, but I want to see if I can make another dedicated emulation machine with this mini pc I purchased. I have already run into a problem however-it seems as though installing CRT emudriver works fine, but when I go to VMMaker, it shows up as basic windows display adapter. when I open up device manager, it shows AMD Vega 11 Graphics(CRT Emudriver), but it says "Windows has stopped this device because it has reported problems (Code 43). How can I get past this?
Separately, is the 2400g capable of making interlaced resolutions in CRT emudriver? as far as outputs on my mini PC, i have hdmi and 2 displayports, no VGA(unfortunately). i purchased hdmi to vga, displayport to vga, and displayport to hdmi adapters(display port to hdmi->hdmi to vga so that i can test forcing 15 khz through displayport. i heard this might be a way to force low resolutions through)
any guidance is greatly appreciated
Substring
  • Last login:December 20, 2025, 03:28:40 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: hp elitedesk 705 g4 2400g crt emudriver setup
« Reply #1 on: September 22, 2024, 02:53:19 pm »
It works with GroovyArcade at least
freakmin
« Reply #2 on: September 24, 2024, 11:05:38 pm »
any input from anyone? is there any info i should provide?
