Author Topic: How to power up with no case?  (Read 1588 times)
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« on: March 06, 2004, 04:02:38 pm »
I am building a bartop cabinet and was getting ready to load my OS on my new PC, and just realized that I bought all of my new equipment but didn't buy a case as I am mounting everything directly into the cab.
My question is, how do I get this thing started without the power on button?  Do they just sell the on/off wiring and connectors that plug into the mobo, or am I going to have to rig something up?  I am assuming I just need to find a way to close the circuit between those 2 tiny little pins on the mobo, just not sure how to go about doing that.
A link or helpful suggestion would be great, thanks.  The mobo is an ECS K7VTA3.
Thanks,
Marty
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
Re:How to power up with no case?
« Reply #1 on: March 06, 2004, 04:21:13 pm »
The mobo will have a jumper for the 'soft power button'  you just need to hook up a momentary switch to that jumper and press it to startup the system.
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
« Reply #2 on: March 06, 2004, 04:41:26 pm »
...or you could go the CMOS route... install an AC on/off switch on the game cab, and set the CMOS to boot the machine after a power failure.
APf
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #3 on: March 06, 2004, 05:49:04 pm »
I just wanted to add that a normal arcade pushbutton is a momentary switch button and that is how I turn on my computer.
jimmyjet
  • Last login:June 03, 2008, 06:39:55 am
« Reply #4 on: March 06, 2004, 06:14:01 pm »
I would love to know more about this CMOS stuff.  Could someone give the step by step info to implement this?  Thanks.
jimmyjet
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #5 on: March 06, 2004, 07:21:34 pm »
jimmyjet, we can't.  BIOS menus differ greatly between manufacturers and even different motherboard models from the same manufacturer.  On most motherboards you can access the bios menu by holding down "Del" when the computer is booting.  From there look through each menu for power-on features.
glitch77
  • Last login:March 15, 2017, 09:25:48 pm
  • Pro Gear Spec!
    • My Hyper NeoGeo 64 Site.
« Reply #6 on: March 07, 2004, 08:51:06 pm »
I know that my Mobo wouldnt turn on without it being inside a case because the ports (ps2, usb, parrellel, etc) were not connected. I simply tied athin copper wire around each ports ground, and it fired right up. Weird eh?
Nailz
« Reply #7 on: March 08, 2004, 12:42:30 am »
Thanks guys, I basically just did what TalkingOctopus was talking about....  I put 2 wires to the prongs on the mobo and connected them to an extra happs pushbutton I have and bingo, works like a champ.
