Author Topic: Golden Tee Fore Complete - Not Booting after Unplug  (Read 1765 times)
jordo90
  • Last login:May 11, 2024, 08:23:15 pm
« on: May 11, 2024, 07:31:51 pm »
Unplugged my Golden Tee Fore Complete. After plugging back in, I get the following error:
161 - Real Time Clock Power Loss
I hit F1 to boot and then get an error saying "Non-System disk or disk error, replace and strike any key when ready"
Any thoughts?
daywane
  • GRRRR!
Re: Golden Tee Fore Complete - Not Booting after Unplug
« Reply #1 on: May 11, 2024, 10:34:14 pm »
This sounds like a computer to me ( hit F1 key) (real time clock)
replace the battery on the mother board. most likely it will be a CR2032 button battery.  Let 5 min pass before installing new battery.
I just do that to 100% know CMOS has reset. Your PC might start up and shut down a few time before you see anything on the screen.
This is normal on some computers, set date and time in BIOS. after all is booted I would scan drive for errors.
that should fix it. Let the computer power up after battery install. Many times I thought Dang PC is shot! be patient just leave it powered on and walk away if you want. take a break. come back and you should see hit F1 screen
