Author Topic: U-trak RGB illumination controller ground  (Read 1175 times)
jmanderson10
  • Last login:April 22, 2024, 05:53:18 pm
« on: April 22, 2024, 11:56:01 am »
Apologies if this is somewhere in the forum and I can’t find it. I have the U-trak RGB controller and I-pac Ultimate I/O board which seems to be a fairly common setup. I’m setting up a trial run of my arcade and can’t figure out how to ground the RGB board. The wiring harness for the I-pac takes up the ground pin location. I’m assuming I am missing something simple but curious how others have it setup. Thanks in advance!
