Author Topic: Verticade: bartop + vpin  (Read 6116 times)
basbase
  • Last login:August 06, 2025, 10:49:41 am
« on: April 20, 2024, 06:14:07 pm »
This is a project that I made in the summer of 2022. After procrastinating for a long time, I feel that I should now do a write up while I have still some memory of the build process. I'm reconstructing the build process based on the photo's that I took, this may cause some written steps to be out of order with what is visible...
The project is a vertical bartop arcade for which my working name was Verticade. I did not come up with a name that I liked better so I just keep calling it that.
It started when the baby dresser was no longer needed. I hate throwing good items away so I figured I use the wood to build an arcade machine. The top plate would be good for building the control panel out of because it is sturdy and has a nice plastic edge. The remaining furniture in the kids room is from the same wood, so an arcade made with it would blend in nicely.
I've been holding on to an old 21 inch full HD LCD monitor for about 10 years now, with the intend to use it for an arcade. I used SketchUp to make a design around this monitor. While playing with the angle for the control panel and the screen, it occurred to me that the ideal angle is about the same as that of a pinball machine play field. So I upgraded the design to serve as a virtual pinball machine when it is placed on it's back.
I did not want to paint the machine nor did I want to add T-molding, so I designed it to use the already finished edges of the wood. All panels would be connected using metal brackets on the inside, so that there would be now screws visible.
I started working on the pinball lock bar early on because I feared it would be difficult to get right and I'd rather fail early. I wanted to use the corners of the top of the dresser for their nice finish on the edges. This would cause a visible cut between the two pieces. To work around this mixed in a white piece from the drawers as this breaks it up nicely and keeps the white accents going. It also happened to be the same thickness as the top which made it ideal.
I had to be very careful to keep the cuts as clean as possible to make the seams flush with each other. It did not turn out perfect, but I can live with the result.
More will follow later..
basbase
Re: Verticade: bartop + vpin
« Reply #1 on: April 26, 2024, 04:26:11 pm »
For mounting the lcd monitor I initially wanted to just use a simple wooden board. But I noticed that a lot of virtual pinball games don't let you change to viewing angle to one that is directly from the top of the playfield, it is usually still at an angle. With the screen already being at the common pinball angle, this would make the playfield angle tilted backward for the player. To combat this, I figured there was some room behind the monitor so I could be tilted to correct the viewing angle. So the simple board became a figure with attachment points for hinges and latches to secure it.
My next challenge was coming up with a mounting system for the control panel. I wanted the panel to be easily serviceable and also removable in case I want to swap it out with a different control panel. On top of that I also did not want any visible screws. I found a solution in using screws as a hinge. I first drilled a big hole that would fit the head of the screw. Then on the side I drilled smaller holes that I filed out to fit the shank of the screws.
Time for some assembly. Here I'm fitting the control panel box together. I used a piece of the dresser with the brand as the front piece because I found it a fitting reminder of it's origins.
I'm using metal angle brackets to connect it all. By not using dowels and glue it would be more likely I could fix any mistakes if my design was insufficient. I had to make the bottom panel in two pieces, because I thought I would have plenty of would from the dresser, and so I used one of the panels as an under layer when I was cutting and it got a lot of saw marks on it. It turned out I dit not have plenty of the would I needed :s. Luckily it was only the bottom so no biggie.
Test fitting the monitor on the mount.
Creating the monitor pivot point.
« Reply #2 on: April 26, 2024, 06:38:42 pm »
Lots of interesting design and problem solving going on in this project! I like that you designed first in SketchUp. I'm not sure what VP software you are using but Visual Pinball allows for direct top down viewing if you configure that way. Direct top down viewing IMO loses something of the realism that some angle and perspective achieves though. Watching for your next updates!  :cheers:
basbase
« Reply #3 on: May 06, 2024, 07:49:32 pm »
The most important pin software for me is Timeshock, since it is my childhood favorite that is still great today. Besides that I run Pinball Arcade. I also think the top down view looks too bland and lacks a lot of detail.
I wanted to use one of the drawer bottoms as a bezel for the monitor. I thought it would be clever to mark the exact monitor position when it was in place, so that it would be a perfect fit.
Well... it turned out like ---steaming pile of meadow muffin---.The monitor was not exactly centered on the stand which made the bezel asymmetric which looked very bad.
So I had to first widen the holes in the monitor stand to allow the monitor to be mounted exactly in the center. Luckily I had multiple drawer bottoms. For mounting the bezel I tried to glue a block on to it and screw that to the monitor stand.
It did not stick... So I just glued the bezel directly to the monitor >:D
I screwed latches on the monitor stand to keep it in place and allow it to be held in two positions.
Because the monitor can tilt on a hinge at the far end, it leaves a gap when in tilted backwards. Because it of the swivel point the trajectory is curved, so I could not make an inner wall to neatly close the gap. I was thinking of all kinds of elaborate movable walls but it was all way too complex. Then it hit me, I would just have to cover the gap with a trim from above, since you then won't see the gap when the machine is on it's back and you are at the pinball player side.
On it's back, but still in arcade mode
On it's back, but in pinball mode
Shot from the back
Starting to look like something
Zeosstud
  • Last login:January 20, 2026, 05:52:04 pm
« Reply #4 on: May 08, 2024, 05:50:05 pm »
You will have a lot of fun with that setup.
Enjoy!!
basbase
« Reply #5 on: May 12, 2024, 06:07:17 pm »
I placed the fixed part of the back panel. And immediately screwed up. What is wrong with this picture?
The monitor was not upright and can now no longer be turned in the right position. Luckily it is easily fixed because it is mounted with bolts.
Most of the back panel will be a hatch. I use a piece of wood to provide some structure to attach a piano hinge with screws.
I pre drilled to prevent splitting the wood.
The control panel was not flush with the sides.
So I attacked with a file:
Time to drill holes for the controls. The control panel will have a single 8 way stick and 2 buttons. This should be enough for most classic arcade games and shmups. I have saved an identical piece of wood in case I ever want to swap it out with a control panel with a different button configuration.
I first drilled pilot holes in the places that felt natural to position my hands at.
I love using the router.
Now onto the actual holes.
For the pinball buttons I made holes for left flipper, left nudge, start, plunger, right nudge and right flipper. For the up nudge I use a autohotkey script to combine to detect when left and right nudge are pressed simultaneously and send a different key in that case. In hindsight, maybe I should have included an additional button on the right to allow magnasave (especially for Timeshock), but I'm now considering swapping right nudge with magnasave if it is supported.
The location of the buttons took quite some fiddling around. I had to find a balance between having a natural feeling distance from the lockbar and leaving space for the monitor bezel to move between arcade and pinball mode.
A monitor, computer and power supply in an enclosed case can get quite warm, so I had to think about cooling the thing. For air intake, I have left a gap between the corner between the back and the bottom. For the outtake, I planned to have a fan at the bottom and the top. This way there is always a fan at the high end, whether in arcade or in pinball orientation, so rising hot air can be exhausted. Both the bottom and back panel are spaced by 1 cm through the sides extending beyond them. This ensures that the fan that is at the bottom does not blow against a solid wall.
A fan guard should prevent chopped up kid fingers.
For the audio department I took apart a pair of pc speakers.
And drilled holes for them in the side panels.
For the brains of the machine I initially wanted to use a Raspberry Pi. But due to covid scarcity those became ridiculously expensive. I found a Lenovo mini pc for a third of the price a Pi would have cost at the time. This also allows me to run Windows and greatly increase the range of software it can run.
To mount the computer, I found the easiest way to be drilling holes in the top case and driving screws through them.
Installed computer, speakers and fans
basbase
« Reply #6 on: May 20, 2024, 06:35:38 pm »
The corners have exposed wood due to the the cuts. To cover these up I use metal corner strips. These will also provide protection against wear and they even look like like pinball legs.
Now onto hooking up the buttons.
To keep the wires in place I screwed in a few velcro strips.
For the wires I repurposed an old data cable I had laying around.
These crimping tools make make the connections very clean and serviceable.
Controller board is hold in place using some screws.
Creating a hole for the power switch and receptacle.
I'm using a 3 socket power strip to power the devices on the inside.
Making sure everything is insulated.
To keep the control panel from opening up I use a latch and an angle bracket for it to hook on to. When I have the machine open from the rear side, I can just manage to reach it.
I've mounted speaker grills, unfortunately the chrome does not match that of the corner strips, but I'm not making a fuss about it because I want to keep costs down.
And this is the final look.
On it's back with screen still up.
And with the screen down for better viewing angle.
« Last Edit: May 20, 2024, 07:19:26 pm by basbase »
basbase
« Reply #7 on: May 23, 2024, 04:46:14 pm »
The build was complete, but when actually playing it I was very disappointed with the performance of the mini pc. The arcade games could not run at an acceptable framerate with any shaders applied, so I could not get a nice crt effect. Pinball games were also pretty much unplayable due to lag. So I had to get an upgrade.
Getting a mini pc with better specs would cost a multitude of what the entire project had cost me so far. I found an alternative in an old HP Elitebook lapotop with a decent graphics chip. The only place where it could fit was on the back panel. I reinforced the plate with some pieces of wood that would also keep it straight. To prevent it from falling of I used velcro strips so that I could also take it to use it for LAN parties. The 240W power brick for this thing takes up almost the entire space that the mini pc occupied. After this upgrade I could run all the fancy shaders and the pinball games are running smoothly.
firedance
  • Last login:Today at 10:42:29 am
« Reply #8 on: May 24, 2024, 12:35:43 pm »
What was the spec of the mini pc, which version of windows was it running ?
I used a dell thin client for my last bartop, windows 10 was way too sluggish so switched to windows 7, much better and plays almost all the vertical mame games ok via a coinops build :)
« Reply #9 on: May 27, 2024, 04:19:31 pm »
I love everything about this. Any plans for art/vinyl/paint?
« Reply #10 on: May 27, 2024, 07:34:28 pm »
I'm also a fan of this especially since you are running one of the Pro Pinball (Timeshock!) games on it.  The physics simulation in them was way ahead of their time. I've played various versions of Timeshock! including the remake Ultra edition. Timeshock! Ultra does not play well on lower end PCs though. I'm not sure if you know, but it is possible to update/customize the music tracks on these games.  The standard music tracks are fine, but it's also fun to mod them.!  :cheers:
basbase
« Reply #11 on: May 28, 2024, 04:48:25 pm »
Lenovo M73 mini PC:
Intel Core i3-2120T CPU @ 2.60GHz (2 cores)
6GB DDR3 ram
Intel HD Graphics
120 GB ssd
Windows 10
HP EliteBook 8560w laptop:
Intel Core i7-2630QM CPU @ 2.00GHz (4 cores)
8GB DDR3 ram
AMD Radeon HD 6700M Series (1GB)
250 GB ssd
Windows 10
The biggest performance increase is probably due to the dedicated graphics card.
The mini pc has now been repurposed to act as the home server in the broom closet. I now use it as a NAS and game server.
An extra benefit of using a laptop in the arcade machine is that it has a battery. Before with the mini pc I would just cut the power when done playing. This is not ideal because important system operations could be interrupted. I believe I also once had a system recovery being triggered on the next startup because of this. Now with the laptop, once I turn off the power switch on the side everything will turn off except the computer. I have a script that monitors the system events for when AC power is disconnected. When that happens the Windows shutdown command is executed for a graceful shutdown. In the bios for the laptop I have enabled the setting to boot when AC power is restored so I can also turn everything on with the power switch on the side.
No plans to add any of these. The wood+white look blends in nicely with the other furniture in the kids room, it is after all made out of the same furniture  :)
It is running a coinops build which has a nice banner for each game at the top, so that takes care of the artwork.
I did misjudge the finish on top of the wood panels. I thought it was a melamine like on My first arcade controls, but it is more like paper. So there is a bigger chance of damage or buildup of grime on the control panel. Maybe I should add some sort of mylar?
I'd even say that the graphics and physics are still better than a lot of the current virtual pinball games (granted I have not played a lot of the latest ones). I didn't know about changing the music, but I wouldn't want to, the music has always been one of my favorite parts of Timeshock!  :D
firedance
« Reply #12 on: May 30, 2024, 08:35:51 am »
Thanks the pc specs, yeah the mini pc would struggle, nice upgrade :)
