Author Topic: help w/arcade game monitor  (Read 2112 times)
jimmyjet
  • Last login:June 03, 2008, 06:39:55 am
« on: March 05, 2004, 03:49:21 pm »
I have a steel gunner 2 cabinet with no monitor.  I took the monitor out of another cabinet, it works, but everything is backwards (steel gunner2 uses a mirror).
Any thoughts on how to reverse the image on the monitor?  Any ideas of other forums where I might get an answer?
Thank you.
jimmyjet
JoeB
  • Last login:May 12, 2026, 07:47:42 am
  • NES Fanatic
Re:help w/arcade game monitor
« Reply #1 on: March 05, 2004, 04:31:59 pm »
The problem is not the monitor, but probably the game board.
See if it has a dip switch to select the monitor installation type.. it's similar to many other games where you tell it to flip or not to flip the video out.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 05, 2004, 06:19:56 pm »
Some monitors have two connectors on the main monitor board that you can plug the yoke into. One gives a normal picture, but if you plug it into the other one you get a mirror image picture. Also, check out www.dameon.net/BBBB/yoke.html
jimmyjet
« Reply #3 on: March 06, 2004, 08:35:15 am »
Thank you both for the promising ideas.  I have accessed the in game menu to change the coin mode, etc.   There is a flid screen option, but that only changes it from right side up to up side down.
I will snoop around for some dip switches today.  Also, that website at Bob Roberts was very informative.
Thanks again.
jimmyjet
jimmyjet
« Reply #4 on: March 06, 2004, 06:16:05 pm »
Everything works 100%.  Thanks again.
jimmyjet
