Author Topic: Modeline for Dragon's Lair in Groovymame on 4:3 arcade CRT?  (Read 2425 times)
kingkatt
  • Last login:March 06, 2024, 12:42:22 pm
« on: March 06, 2024, 12:42:22 pm »
As the latest version of MAME now supports Dragon's Lair, I thought I'd try and get it running on my setup. I have Groovymame 0.263 running on a Windows 10 PC connected to a tri-sync arcade monitor in a Sega New Net City cab.
The game runs just fine, but it looks like it is using the 2560 x 480 super-resolution. The scoreboard is partly visible on the right, the player text in the scoreboard is squashed, and there are obvious interlacing artifacts in the game video.
I tried adding a dedicated 704 x 480 modeline in Video Mode Maker, but it looks like the game is still using the super-resolution.
What should I change in VMM so that the game will 1) run in native resolution with the video part filling the screen and 2) run with interlaced video? Is it possible?
Calamity
  • Moderator
  • Last login:January 23, 2026, 06:10:10 am
  • Quote me with care
Re: Modeline for Dragon's Lair in Groovymame on 4:3 arcade CRT?
« Reply #1 on: March 07, 2024, 03:30:03 am »
Hi kingkatt,
If the resolution is available, you can force it through the resolution option, like -r 704x480
Anyway, it should look exactly the same with a super resolution as it would with a "native" one.
I haven't tried Dragon's Lair yet, but you can expect interlace artifacts provided in-game interlace video fields won't match the fields of our interlace video output, and there's nothing that can be done about it (easily).
Steps to create a log:
