Author Topic: This looks usefull for older comps  (Read 1192 times)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« on: March 05, 2004, 11:42:17 am »
Curls in the squat rack !?!?!
SirPeale
  • Green Mountain Man
Re:This looks usefull for older comps
« Reply #1 on: March 05, 2004, 12:55:58 pm »
You've never seen that before?  :o
Edgedamage
« Reply #2 on: March 05, 2004, 12:59:37 pm »
No and this is the pic that got my intrest. And this little write-up also got me thinking:
For a home theatre PC, low noise is very important, and the VIA EPIA M-10000 does very well at keeping the noise level down. However, the board is not the only component in that setup, you have a harddrive and a DVD ROM drive. The harddrive I was using was far too noisy, so I decided to go with solid state, a 128MB Compact flash and adapter. I used Windows 98 as Windows XP is far too big for a compact flash. Together with program called LitePC (free version) and some careful file pruning I was able to get the 98 install to under 90MB. With all the codec installed and a program called Media Engine. I was set to go. I was also using a Pioneer DVD ROM drive and was able to lower the noise of that by slowing it down with some Pioneer utilities.
Booting from Compact flash is a lot quicker than I initially thought. With Windows98 booting to the desktop within 25 seconds.
dommer
  • Last login:February 20, 2016, 06:54:10 am
« Reply #3 on: March 07, 2004, 07:38:16 pm »
Where can you get that CF to ATA adapter?  That is pretty slick.  Nerdy sense... tingling...
