Author Topic: Groovyarcade Setup Questions  (Read 2370 times)
Tempest_2084
  • Last login:March 03, 2024, 03:48:25 pm
« on: February 26, 2024, 09:54:16 pm »
I have a few questions about setting up Groovyarcade, hopefully they're not answered somewhere else.  I'm using GroovyArcade with my PVM 1943MD via an Radeon R7 260X.
1. The main OS screen is shifted too far right.  I can shift the image to center for the actual emulator, but not the OS screen.  Is there a fix for this?
2. Can GroovyArcade do C-Sync?  Right now I'm using H and V Sync and it works fine (via an old VGA monitor cable that used BNC connectors), but I want to use this with my SCART switchbox which means I need to use C-Sync.
3.  I have a bunch of roms on a second drive (not the boot drive).  How do I access these from the emulator to add them?  It's actually a Windows formatted drive but it should show up in Linux.  I looked in /mnt but it's not showing up.  I think I need to mount it first, but I'll be darned if I remember how to do that through the command line
4. Assuming I can't read the windows drive, how can I format and auto mount this second drive so I can store roms on it?  The drive is much larger than the boot drive and I'd like to use it.
Substring
  • Last login:December 20, 2025, 03:28:40 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: Groovyarcade Setup Questions
« Reply #1 on: February 28, 2024, 02:15:48 pm »
I guess you had all your answers on discord ;)
but for others :
1. Once you've centered your screen using the geometry tool, you must set a custom resolution as of you wanted to change your boot resolution
2. No, can't csync. There are tons of ways to achieve csync out of your computer
3. and 4. : yeah, manually, with a few things to edit here and there
