Author Topic: I-PAC 2 firmware upgrade issue  (Read 1435 times)
roy6585
  • Last login:January 30, 2024, 02:36:13 pm
« on: January 30, 2024, 08:31:00 am »
Hello,
I'm hoping someone can advise me on how to correct my firmware upgrade issue.
I have a post 2015 ipac 2 (I believe this to be a post 2015 because of the mini usb connector on bottom of board). It is currently on firmware 1.44. I would like to upgrade the firmware to multimode so I can switch the board to x-input.
I have downloaded the firmware from the Ultimak site. When I run winpac2 and start the firmware upgrade, my board goes into resetting mode, then the secondary program pops up to select firmware , but my board is not detected again. Not sure why after resetting the board, it is no longer detected by my PC.
Any info would be greatly appreciated.
Thanks,
Roy
