Author Topic: Streets of rage 4 on 4-player cabinet  (Read 2817 times)
ababb
  • Last login:January 01, 2024, 11:55:28 pm
« on: December 29, 2023, 06:17:27 pm »
My first attempt at a 4-player cabinet build. I am using Hyperspin as the frontend and an Ultimarc ultimate i/o controller interface. I was going to load Streets of Rage 4 into Hyperspin via Steam. But I am not sure the game, when loaded in Hyperspin, will identify the 4 joystick controllers. Any suggestions?
I was thinking the only solution may be to use xpadder, and hope this works, but I haven't used this before.
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
Re: Streets of rage 4 on 4-player cabinet
« Reply #1 on: December 30, 2023, 02:21:43 pm »
Hyperspin shouldn't affect how any game sees gamepad/joystick devices so if it's working in Steam/Windows, it should still work in Hyperspin.
  • Last login:Today at 07:17:48 am
« Reply #2 on: December 30, 2023, 02:48:07 pm »
Not on topic, but you should install Streets of Rage Remake which I’ve found to be a much better game.  Personally was not a fan of Streets of Rage 4 and I can probably beat 1 and 2 blindfolded.  SORR can be found via simple google searches.
I do dimly recall there was some control issue with multiple players and SOR4.
Again, I know this is a zero value post.
ababb
« Reply #3 on: January 01, 2024, 03:47:10 am »
Ill definitely check that out. Thanks
