Author Topic: Groovyarcade + Attractmode - Front End incorrect rotation  (Read 2473 times)
GroggyExpulsion
  • Last login:July 15, 2025, 05:39:43 pm
« on: December 01, 2023, 08:01:46 pm »
I have an Astro City with a monitor rotated 90 degrees to the right.
In gasetup i have choose the orientation to be rotated right
On initial boot attract mode is orientated correctly and games display correctly
When exiting a game, attract mode will be rotation incorrectly, at this point, setting attractmode to flipped will fix it. If i do this though on next restart the first time attract mode loads it will be wrong, and then only be correct again once i have loaded a game and then exited again.
Going into the orientation settings for attractmode does not fix it either, it will just through everything out by whichever rotation setting i set..
I hope this makes sense :)
Substring
  • Last login:November 20, 2025, 01:04:47 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: Groovyarcade + Attractmode - Front End incorrect rotation
« Reply #1 on: December 08, 2023, 06:08:43 am »
HI,
First of all :
- which iso have you used to install ?
- have you fully updated since ?
oomek
  • Last login:October 24, 2025, 01:13:40 pm
  • Mame forever.
    • https://github.com/oomek
« Reply #2 on: December 08, 2023, 06:30:03 am »
What is your Attract-Mode Plus version?
GroggyExpulsion
« Reply #3 on: December 09, 2023, 04:33:49 pm »
Complete stupidity on my part.. installed the rotationfix plugin at some point and forget about it
