Author Topic: Suggestion  (Read 3884 times)
tony
Suggestion
« on: February 28, 2002, 09:12:27 pm »
ok, i'm a newbie (and proud of it!)
my suggestion is to have more sub categories.  i've had different questions on my first project and i think it would be convenient to have:
build your own controllers
need help with monitor
pc issues
etc.  hope this makes sense...
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
Re: Suggestion
« Reply #1 on: March 01, 2002, 04:43:56 am »
I personally like the broader categories. If you split it up too much you'll be waiting longer for a response. Because if I'm not having monitor issues, I'm probably not going to go in to that section and I might know the answer to your question. Also I think the generic categories will clean up some once the faq gets set up. Thats where I think they should have the more specific sub categories. You want it broad so you get everyone seeing your post not just other people currently working to figure out the same issue.
