Author Topic: PSA: You'll have to reinstall CRT Emudriver if you update to Windows 23H2  (Read 3124 times)
CRTFTW
  • Last login:November 25, 2025, 10:27:00 pm
I just installed 23H2 and it apparently partially uninstalled Emudriver and my analog output defaulted to 1600x1200, which was a pain in the ass because my 5:4 LCD won't display that resolution either.
VMMaker still showed all my settings correctly, so I thought Emudriver was still installed. But then I opened Setup.exe and saw that my card was recognized but the driver itself was no longer installed.
So yeah, I hit install, and everything returned to normal, and my settings + resolutions were still present from the previous install.
buttersoft
  • Last login:Today at 04:20:06 pm
  • Is running at 15kHz
Re: PSA: You'll have to reinstall CRT Emudriver if you update to Windows 23H2
« Reply #1 on: November 19, 2023, 10:52:46 pm »
Always a pain when Windows updates kill crt_emudriver. This is for Win 10, here? I can't say i've had Windows default to 1600x1200 though, that might be tricky to handle.
CRTFTW
« Reply #2 on: November 20, 2023, 04:10:03 am »
It's Windows 11. On a r5 430.
First time I'd seen 1600x1200 in a situation like this too. Not the most compatible mode for Windows to pick out of a hat.
