Author Topic: X-Arcade Tankstick USB Mod Question (installing a USB Hub)  (Read 4146 times)
websherpa
  • Last login:October 13, 2024, 09:50:28 am
« on: October 23, 2023, 11:20:08 pm »
Call me a glutten for punishment, but I got it in mind to convert my spare Tankstick BACK to the original updated X-Arcade controller PCB (from an I-Pac Ultimate conversion I did, to use that in another build).  All good except that I am rather fond of installing a USB hub inside my pre-built controllers to add things like Spinners so there is only one simple USB cable hanging out the back.
It works fine if I coil up the long original 9 pin PCB header female connector to Serial/USB/PS2 cable inside and connect to the USB hub, but I have built 2 shorter custom USB to 9 pin PCB header connectors now, and neither works as expected.  Both short hacked cables light the Tankstick’s Power LED, but do not seem to be transmitting USB data.
I’m pretty sure (having traced from original at least 6 times to be sure) that I have the correct pinout configuration (unless I am missing something really obvious), however I am asking to see if anyone else has built a straight USB cable for the TankStick in this fashion and if so, any ideas what my issue might be? (Or maybe a pinout diagram I can check mine against?)  The USB shielding appears to be just floating and not connected to anything at the PCB end of things.
THanks in advance if anyone picks up on this and can help me!
Or would I be better off connecting to the 4-pin PS2 PCB header instead?
  • Last login:February 23, 2026, 08:25:01 am
Re: X-Arcade Tankstick USB Mod Question (installing a USB Hub)
« Reply #1 on: October 24, 2023, 09:29:07 am »
That's your problem.
websherpa
« Reply #2 on: October 24, 2023, 11:54:25 am »
When I tested the original cables, ther doesn’t appear to be any connection between the original Tankstick connector USB /PS2 cables’ sheilding and any pin on the 9 pin PCB connector.
Sorry, I am going from PCB 9 pin connector to USB-A and Pin 9 on the PCB Header IS the shield for the Serial connector, and is connected to Pin 1 of the USB-A Male. (But there is no connection on the original to the USB-A end shield.)
I tried again using a pinout found on here, but still no dice, I only get power and no data and the data connections appear to be as expected and not reversed.
I haven't tried to test continuity on the Encoder Board though, there is always a remote chance one of the pins isn't connecting to the female connector.  So that's next.
Then I am going to try going from the 4-pin PS2 connector straight through to USB (inactive) to see if that will work instead.
. (I am realizing now that the 4 pin PS/2 header on the X-Arcade encoder is an INPUT for programming the board directly from a PS/2 keyboard, that the 9-pin serial header is, I think, split off to USB-A and PS/2 PC mobo connectors.
Still I am now suffering pseudo-OCD to determine why my new connector isn't working.
« Last Edit: October 24, 2023, 01:31:44 pm by websherpa »
timcannell
  • Last login:October 23, 2024, 12:57:02 pm
« Reply #3 on: October 01, 2024, 04:43:38 pm »
I have also configured my tankstick with an internal usb hub and single external USB cable connection.
I have used a multimeter to determine connections from the 9 pin connector to the USB pins (as shown in the attached image) and was about to cut the stock cables up and make one usb cable when I found your post.
Did you have any luck with creating a working cable?
« Last Edit: October 01, 2024, 05:00:39 pm by timcannell »
x-arcade
  • Last login:October 26, 2024, 02:38:01 pm
« Reply #4 on: October 26, 2024, 02:17:00 pm »
I used to work for Xgaming.  Retired now.  Have some cables/wiring, send me your address and if u in USA, will send free.  If u in Canada, just send me prepaid label and can drop at post office.
