Author Topic: Lines cutting  (Read 11368 times)
jteexy
  • Last login:November 24, 2025, 06:44:50 am
Lines cutting
« on: September 22, 2023, 08:47:57 am »
What is the best way to go about cutting MDF where two pieces of the cab share the same line (such as in Lusid's Plans)? I don't want pieces to be 1/16th off when I go to put it together
RobodocX
  • Last login:January 07, 2024, 05:22:54 pm
  • Looking to help with woodworking questions.
Re: Lines cutting
« Reply #1 on: September 27, 2023, 11:31:05 pm »
I think the reason you aren't getting any replies is that your question is too general. To provide help we need to better understand what tools you have available to you. The "best" way to cut MDf would be with a large CNC machine and a vac table or perhaps a sliding table saw but of course most people don't have easy access to those tools. Likewise, a good quality tracksaw does a very nice job as well even for long pieces. If you can provide some info as to what tools you have for cutting MDF sheets we can provide better guidance. Do you have a tablesaw with a fence? Do you have a circular saw that could be guided with an inexpensive straight edge? Generally those approaches are going to give you a better result than an unguided options like a jigsaw.
Richard
Woodworker and computer builder.
Traditional, digital design, CNC and laser techniques. Always happy to help if I can.
yamatetsu
  • Last login:Today at 01:03:03 pm
  • Just because.
Re: Lines cutting
« Reply #2 on: September 28, 2023, 03:42:30 am »
You misunderstood the question. It's not about which tool to use, it's about where to cut.
He's got a plan like this:
Now the question is whether the line is part of the board to cut or not. If it's part of the board, you would cut close to the line, leaving it intact. However, if you cut like this, cutting out board A would remove the thickness of your sawblade + the thickness of the line from board B.
So the answer to his question is to cut on the line, thereby removing equal parts from board A and board B.
However, this is probably moot because the OP didn't bother to log in for 6 days.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 06:39:13 pm
Re: Lines cutting
« Reply #3 on: September 28, 2023, 05:40:49 am »
Add the width of the saw's teeth or blades to your cutting measurements, to allow for "wastage".
RobodocX
Re: Lines cutting
« Reply #4 on: October 01, 2023, 08:21:25 pm »
Ok. Well figuring out that would simply require looking at the whole plan and doing whatever you chose to do symmetrically. This is wood we are talking about here so the issue of the saw kerf is likely not a big deal provided you do the same thing to each side. Given that many table saw blades are 1/8", and that is the likely largest kerf you are going to be making, you are talking at most about building a box 1/8 inch larger or smaller than the plan defines. If there are critical tolerances in a standup cabinet less than 1/8" I would be surprised. However, that should be pretty evident from the whole plan.
Richard
lilshawn
  • Last login:Yesterday at 11:01:31 pm
Re: Lines cutting
« Reply #5 on: October 02, 2023, 05:35:39 pm »
i mean, when it comes to cutting wood (plan or no plan) you don't lay it out in pencil on the wood like it is in the picture and go ham... it's laid out like that to show you how it can all fit on a sheet. it's up to you to look and see "oh i need a 24 7/8" x 22 1/2" piece" and so you cut that off your material. "next I need a 19" x 19 1/2" piece" and so you cut that off your material that's left.
one does not turn a 24x12 piece into two 12x12 pieces with a saw. you end up with a 12x12 piece and a 11 7/8" piece.
Re: Lines cutting
« Reply #6 on: July 06, 2024, 01:02:08 pm »
I think the best way to get two panels identical (such as cabinet sides), is to cut out one panel, smooth it and and get it "done", then lay it on top of a new piece of wood and mark it on the "new" wood, maybe just a little bigger than the done panel.
then remove done panel, cut out new piece with jigsaw or whatever, then replace done panel and clamp it to new piece. Then take router with proper bit and trim new piece to match done piece exactly.
im sure there are easier ways but i like doing things the hard way, apparently. LOL
lilshawn
Re: Lines cutting
« Reply #7 on: July 06, 2024, 06:22:14 pm »
yeh, if i need 2 identical pieces (and they aren't just square... such as the side of a arcade cabinet) i'll cut one out and like you say... get it finished to size and sanded or whatever... then double sided tape a rough cut piece to it. then using a 1/4" flush cutting bit with a bearing on the end... and trim all the way around. Viola! 2 identical pieces.
