Author Topic: Can I possibly cut wires on a set of speakers and solder on another set of speak  (Read 1288 times)
jteexy
  • Last login:November 24, 2025, 06:44:50 am
I think the answer in no, because I don't think it works like with electricity, but just in case I'm wrong I'm going to ask. Can I possibly cut wires on a set of speakers and solder on another set of speakers? So from output to 2 it's outputting to 4 speakers? And let's say the values are the same (impedance or what not) 6ohm. Thanks In Advance
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
Short answer = no, not like you're currently thinking.
Longer answer = yes, after some additional understanding (and different speakers).
This page will explain: https://soundcertified.com/speaker-wiring-diagram-guide/
You'll want the ohm load of the new speaker system to be the same as the ohm load of the original speaker system.
Mordac85
  • Last login:September 25, 2024, 07:54:58 pm
You should also consider if your audio source has the power to drive the additional speakers.
