Author Topic: LEDBlinky and I-PAC Ultimate Help  (Read 3574 times)
fasteddy
  • Last login:September 12, 2023, 07:09:43 pm
« on: September 12, 2023, 07:28:49 am »
I'm banging my head against the wall trying to get LEDBlinky to play nice with an I-PAC Ultimate board over here.
I decided to do a partial upgrade by ditching the zero delay encoders and adding an I-PAC Ultimate. However I'm keeping my Amazon EGStarts buttons for now.
The buttons have 3 pins, but I got them to work with the i-pac by connecting pins 1 & 3 to the led + and numbered ports, and the middle pin to the player pins. This lights the LEDs and registers inputs from the buttons. Awesome so far. But I can't get LED Blinky to control the LEDs. Led test doesn't do anything, and when using the wizard no LEDs blink. (edit: the simple LED test does have an almost imperceptible dimming across most - but seemingly not all - of the LEDs when I slide the intensity slider up and down).
Even removing the middle pin for the button input and leaving only led+ and the led port on the i-pac dies nothing - LEDs all stay lit.
I also attempted to directly wire a bare LED, to the board. Again, it lights up, but the simple LED test does seemingly nothing, and when using the config wizard it doesn't blink.
Any ideas?
(Edit: should also probably point out that the LEDs are all constantly lit. My understanding is that they're supposed to do some kind animation on power startup of the i-pac, but they just light up, nothing else ,)
« Last Edit: September 12, 2023, 07:47:36 am by fasteddy »
