Author Topic: setting up X-arcade .ini in commandline MAME  (Read 3972 times)
killbill
  • Last login:November 05, 2025, 02:53:17 pm
  • When I die, I want to go to arcade heaven!
« on: March 04, 2004, 02:22:33 pm »
Hi,
How do I get the X-Arcade default controller settings to work in commandline MAME?
I am running MAME.79 through MAMEWAH.
Tiger-Heli
    • Tiger-Heli
Re:setting up X-arcade .ini in commandline MAME
« Reply #1 on: March 04, 2004, 03:39:58 pm »
Hi,
Make the following settings to your MAME.ini file (if you don't have one, run MAME -cc from the commandline
### Windows path and directory options ###
ctrlr_directory         ctrlr
or C:\MAME\ctrlr
### Input device options ###
ctrlr                   XArcade
The default ctrlr.ini files come with MAME
killbill
« Reply #2 on: March 04, 2004, 05:07:39 pm »
Hi Tiger,
thanks for the response.  I don't see a mame.ini file and I've only launched MAME through the Mamewah frontend.
How do I launch Mame -cc?  And do I create the mame.ini in there?
Thanks.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: March 04, 2004, 05:14:54 pm »
Hi Tiger,
Thanks.
Might depend on your OS, but typically you run Start-Programs-Accessories-(MS-DOS Prompt or Command Prompt).
From here -
Type "cd\" <enter>
Prompt should show C:
Type "cd MAME" <enter>
Prompt should show C:\MAME
Type "MAME -cc" <enter>
mame.ini will automagically appear in the C:\MAME folder and you can edit it with Notepad
killbill
« Reply #4 on: March 04, 2004, 06:02:03 pm »
Hey Tiger,
Thanks for the help.  I got the MAME.INI file to show up.
Do I have to mess with the "# inipath" option or just the two things you mentioned above?
Also, once set up, this MAME.INI file with always set MAME up to run with the XArcade defaults right?  Even when accessing through my front end?
Thanks Again.
« Last Edit: March 04, 2004, 06:03:17 pm by killbill »
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 04, 2004, 06:29:59 pm »
Hey Tiger,
Thanks Again.
# inipath is for per game .ini file changes (not ctrl.ini file changes).  Like if you wanted Space Invaders to run with scanlines and none of your other games to.  Setting or not setting it won't affect the key assignments.
AFAIK, mame will run with the XArcade defaults except - If u change assignments with the TAB key, MAME saves these in a .cfg file and overwrites the ctrl.ini assignments, or if MAMEWAH is set to overwrite or ignore the ctrl.ini files (I doubt it, but don't use it  . . .)
killbill
« Reply #6 on: March 04, 2004, 07:03:18 pm »
Thanks for your help, Tiger.  You da man!
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 04, 2004, 07:05:11 pm »
Glad it worked
