Author Topic: Two GPUs with CRTemu driver  (Read 3396 times)
haynor666
  • retro maniac
« on: August 12, 2023, 03:17:53 pm »
Will CRT driver and mame works with two Radeon cards so I could show horizontal games on one and vertical games on second?
Right I have such configuration but with one GPU but two analog outputs. Sadly all new GPUs have only one analog output so option would be to put two GPUs since many motherboard have such option.
Milsancho
  • Last login:November 20, 2024, 06:09:37 am
Re: Two GPUs with CRTemu driver
« Reply #1 on: August 13, 2023, 04:19:58 am »
Out of curiousity as I'm building a dual monitor set currently, what's not running properly with you current configuration? Or is it just that your current Radeon needs repair?
haynor666
  • retro maniac
« Reply #2 on: August 13, 2023, 02:43:47 pm »
Radeon is fine. It's just old and weak for example for Naomi emulation.
Milsancho
« Reply #3 on: August 13, 2023, 04:14:36 pm »
That's my question, as I'm looking for another card and, like you, I prefer the HD 5XXX series for dual analogue. Which other examples than Naomi (and I guess DC as well?) do you have where a 5XXX series is not able to get it running (at 640 x 480)? Type X and other PC-based arcades?
Have you tried with an HD 5770 or 5850?
« Last Edit: August 13, 2023, 04:17:48 pm by Milsancho »
buttersoft
  • Last login:Today at 08:46:18 pm
  • Is running at 15kHz
« Reply #4 on: August 13, 2023, 08:34:15 pm »
I would imagine other PC-based arcades, yep. A lot of the TeknoParrot games, for example.
haynor666
  • retro maniac
« Reply #5 on: August 14, 2023, 11:32:58 am »
Naomi through RetroArch/flycast core is ok. The same goes to early Taito Type X/X2 games. Newer Taito Type X and other PC hardware based games require more power but also does not work with 640x480 do it does not matter in this case.
I was thinking simply about build "bullet proof" but cheapest as possible hardware sbased on  only new parts. In this case it would be two modern GPUs since all new Radeons does not have two analog outputs. I think I have somewhere another Radeon but I would to know if someone tested new cards with such configuration rather old HD5xxx serie.
Milsancho
« Reply #6 on: August 14, 2023, 12:33:53 pm »
Can you really buy today new Radeons with even just one analogue out?
And when you're excluding the HD 5xxx series you also mean high-end cards like the 5850, or is it that these aren't verified to have two analogue outs?
haynor666
  • retro maniac
« Reply #7 on: August 18, 2023, 06:54:21 am »
I would prefer two low cost new Radeons with single analog output (still there on market such cards). Any new low cost Radeon would be better than my old HD5450.
Milsancho
« Reply #8 on: August 20, 2023, 02:16:33 am »
Any retailer in Europe you recommend to find those cards? Thks.
Edited to add: I meant, something not being no name chinese units. Im seeing there are even brand new R7 350 for 50€ with VGA but are those really trustworthy?
« Last Edit: August 20, 2023, 05:20:41 am by Milsancho »
haynor666
  • retro maniac
« Reply #9 on: August 20, 2023, 03:17:26 pm »
It's hard to find something trustworthy. Most cards with single analog are in fact chinese product but on used marked I've found some Asus R7 cards that have one analog output straight from analog dsub that is build directly into pcb.
