Author Topic: CH288 CHASSIS BOARD SCHEMATIC HELP!!  (Read 1900 times)
Irish_cab_collector
  • Last login:August 06, 2023, 10:56:04 am
« on: August 06, 2023, 10:50:34 am »
So I've done some due diligence and taken photos of most of my caps when I take them off the board. But at the start of this while waiting for the caps to come I took some off and now I can't remember what they were! Does anyone have a easy to read schematic or even cap kit that was used for this particular chassis if so it would be much appreciated 👍
buttersoft
  • Last login:Today at 05:35:04 pm
  • Is running at 15kHz
Re: CH288 CHASSIS BOARD SCHEMATIC HELP!!
« Reply #1 on: August 06, 2023, 07:03:21 pm »
is the PCB not stencilled in any way? on newer PCBs caps are often given a picture of  half-and-half shaded circle, which indicates polarity (though the odd manufacturer insisted on showing things in reverse). I have no idea how old your chassis is though.
  • Last login:January 23, 2026, 01:40:05 pm
« Reply #2 on: August 07, 2023, 09:09:21 pm »
one should remove components one at a time.
especially with capacitors, as you can tell the orientation as you pull it out.
https://www.arcade-museum.com/manuals-monitors/Pentranic%20CH-288%20Switchable.pdf
also, there is tons of pics on google. you should be able to see what you are missing from them. google "ch288 chassis" and select images
« Last Edit: August 07, 2023, 09:11:06 pm by lilshawn »
