Author Topic: Interfacing motorcycle /bike Cab (Namco Gp 500) controls to PS5  (Read 6416 times)
rmwilson
  • Last login:January 17, 2024, 04:39:29 pm
I have a namco Gp 500 motorcycle racing cab
I have three outputs via potentiometers from the cab (left/ right) (throttle) and (Brake)-
Anyone find a GOOD way to take these output values send them to a ps5 controller so I can then play modern ps5 Motorcycle games while still using the arcade bike as the controller... ?  (can be custom arduino boards or software or things like ps mod chips that makes for easy solder connections to triggers and yokes?
Any and all thoughts welcomed,
Thanks,
Ryan
buttersoft
  • Last login:Today at 02:01:17 am
  • Is running at 15kHz
Re: Interfacing motorcycle /bike Cab (Namco Gp 500) controls to PS5
« Reply #1 on: July 13, 2023, 07:26:15 pm »
Are there still pots in a PS5 controller? Those analog joysticks and triggers are probably still based on pots. i would google projects where people have opened up a PS5 or even PS4 controller and wired to the inputs. There might also be boards made by companies like Brook, but those things often don't have analog. There are certainly projects out there with people soldering directly onto the PCB's for Xbox360 controllers, i was thinking something similar.
MrThunderwing
  • Last login:February 21, 2026, 03:10:59 pm
« Reply #2 on: July 19, 2023, 05:09:22 pm »
Ditch the Namco gear, go proper old skool with one of these bad boys for your bike games
buttersoft
« Reply #3 on: July 19, 2023, 07:09:23 pm »
Analogue simulation in digital controls! Genius ;P
MrThunderwing
« Reply #4 on: July 20, 2023, 05:18:43 am »
Analogue controls are overrated Butters  :P
Real men use digital  8)
rmwilson
« Reply #5 on: August 02, 2023, 11:04:27 pm »
I can most certainly appreciate the novelty of it but having the FULL namco bike is a tad cooler ...( to sit on and lean and have throttle and brake)
baritonomarchetto
  • Last login:February 20, 2026, 01:04:30 am
« Reply #6 on: August 03, 2023, 02:13:27 am »
I converted a Suzuka 8 hours years ago to work with a PC. I used a properly programmed arduino as interface.
I set up a couple of Moto GP games (don't remember, maybe moto gp '18) and Milestone's superbike 2000. My findings where that only superbike was playable. This was not because of the PC, nor the interface but the faact that motorcicle games optimized for gamepads are not "compatible" with a whole bike controller. Motorcicle games have a programmed lag intended to simulate a real bike. With a gamepad that lag is beneficial. With a full motorcicle controller (cabinet) you have an additional lag due to the cabinet inertia.
In other words simulation lag + cabinet inertia make those bike games unplyable on arcade hardware
Different is the case of arcade games such as hang on series, taito world grand prix etc. Those are still hard to play because of the cab inertia, but enjoyable.
« Last Edit: August 03, 2023, 02:18:49 am by baritonomarchetto »
MrThunderwing
« Reply #7 on: August 06, 2023, 03:53:09 pm »
I stand corrected  :lol That looks pretty damn awesome!
Xiaou2
  • Last login:Today at 01:29:36 am
  • NOM NOM NOM
« Reply #8 on: August 07, 2023, 05:50:34 am »
Actually... even Arcade motorcycle games that had Sit on versions... were Impossible to play well.
A perfect example is Super Hangon.  Ive played both the Standup and Sit-On version of it.   The game itself, is downright Brutal in
its difficulty level..  and that is with the quick standup controls.   Trying to move the cabinet with your legs... makes it impossible, IMO.
The problem is that the Spring mechanism cant replicate the quick self-righting nature of the spinning tires Gyroscopic nature.
 A few ideas on building a functional sit-on controller:
1)  Make the pivot closer to the center of the bike, and make the leaning mechanism resemble a Parallelogram... where you
shift the entire structure to the left or right.
2)  A bit more crazy:  Make an actual spinning tire, to act as a Gyroscope.  The speeds would have to be dialed in, in such
a way.. that they are able to hold your mass up good enough.. but not so strong that you cant lean the bike.  Again, you still
would likely have to raise the pivot closer to the center.   This would probably require a Weight sensor in the seat.  Tires would
have to be enclosed for safety.  And it still might fail to work as expected.
3)  Motor Driven mechanism.  Sort of like a CNC machine.  Depending on the Degree that you turn your handlebars... the
more that the bike will Lean.   To be able to react fast enough.. you will probably need something like a Chain Drive mechanism,
and good strong gearing.
A good Counter-Mass system, might make physical transitions even more effortless, and speedy.
Now... to go all out... you would add a Z-Axis (height control)  for Hill Simulation.  One for each Tire.  They might also serve
to act as road bump simulation (haptics).
If the Entire platform could rotate 360 degrees... you could also have a pretty realistic VR solution.
 But the simple Parallelogram pivoting system, could be a pretty easy build... and give enough of good feel, that it satisfies most
peoples desires (just enough).
Xiaou2
  • NOM NOM NOM
« Reply #9 on: August 07, 2023, 06:22:42 am »
This was a very quick mockup.  I think the pivot probably has to be places higher up... I just dont want to redraw it at this point.
rmwilson
« Reply #10 on: January 17, 2024, 04:39:29 pm »
Interesting ... the MNAXX operates like this - and I hated it the bike was more of a swing /and pivot rather than a lean .... I hunted for namco GP so i could get the lean - I am sure I can find someone to build a arduino controller that takes the analog outputs from the Pots on the arcade and converts that to the mapped equivalent signal the PS5 is expecting ... with a bit of MATH I am sure someone way smarter tha me could figure out - ok the bike moves the pot x amount and that is y amount of movement on the ps5 stick  (for the left to right) and same for brake and throttle - eg half throttle is this value on arcade and thus this would equate to y value on ps5 joystick trigger
baritonomarchetto
« Reply #11 on: January 18, 2024, 01:13:12 am »
There's no "smart" math involved here: it's a matter of phisical limits of the hardware itself as me and others are trying to explain. Scaling the axis to get an appropriate full range span is super easy with microcontroller boards.
This is a link to my project, just in case:
https://youtu.be/5bScGFOAH1k?si=bd75YKQlmm4jL1U-
« Last Edit: January 18, 2024, 01:15:17 am by baritonomarchetto »
