Author Topic: Best joystick for Robotron on Mame cabinet that needs 4-way and 8-way joysticks  (Read 2224 times)
NorthPortFL-Pinball
  • Last login:December 22, 2023, 10:12:46 am
Hi everyone,
I just found this forum tonight.  Great to see so many people willing to help others.
I was reading this thread regarding the best joystick for Robotron ( http://forum.arcadecontrols.com/index.php/topic,163836.40.html ).
I have an older Ultracade multi arcade system I bought about 10 years ago. We bought it primarily because it had Robotron on it (my wife and I love this game). I bought an XXXX-IN-1 system that died, so we are back to playing Robotron on the Ultracade system.
I purchased the Ultimarc Mag-Stik Plus joysticks so we could switch from 4-8 player from the top panel.  The joysticks work, but it can be really frustrating.  When playing Robotron, the diagonal/45 degree angle shots work well, however up/down/left/right shots are problematic.  Many times the joystick just won't shot up/down/left or right when we need.  I've tried adding a joystick extender to the top of the joysticks, but that has had very little effect.  I also don't see how I could improve the leaf switches to fix this problem.
I am planning to retrofit the Ultracade with a Windows based Mame computer with a new panel for the joysticks and buttons.  So, I'll still need to be able to have 4 way and 8 way playability.  Ultrimarc now makes another joystick called "ServoStik".  Not sure if that would be any better.
I know having a dedicated Robotron machine is obviously the way to go.  But what would you recommend doing in a Mame cabinet situation?
Thank you.
BlueGhost
  • Last login:February 05, 2026, 07:27:03 pm
GRS makes a 8/4 way servo kit that works with JLFs and their clones.
Here's the kit with a servo for one joystick:  TOS GRS Switchable 4-to-8-Way Restrictor for Sanwa Joystick | All in One Kit
It will control up to 4 joysticks, here's the add on for an additional stick:  TOS GRS Switchable 4-to-8-Way Restrictor for Sanwa Joystick | Extension kit
I have a pair with a set of JLFs, I don't have them in a cabinet yet, but I have hooked them up and tested them.  You can toggle them from a button or via an executable you call from a script.
NorthPortFL-Pinball
Thanks BlueGhost.
When you get it working, can you let me know how that plays with Robotron please?
Thank you.
