Author Topic: The All Thing Shape Shifting Traveler from Zero Space! - An Anti-cab build.  (Read 19162 times)
griffindodd
  • Builds Stuff
In this build I'm going to convert my existing wall-mounted dual screen theater sign into a shape-shifting freak anti-cab that can become many things and perform many functions.
Let's get weird baby!
« Last Edit: April 17, 2023, 02:16:17 pm by griffindodd »
I drink and I know things.
griffindodd
  • Builds Stuff
For the front end I'll be using a combination of existing solutions.
- Arcade - CoinOPs Legends 4 Vertical
- Pinball - Pinup Popper
- Karaoke - KODI
- Signage - Existing server-based via web interface.
griffindodd
  • Builds Stuff
Functions required from this build.
At Home (Docked):
- Up to 4-players at an arcade-style Control Panel that plugs into a local gaming computer and AV.
- Arcade experience shows Full cabinet with playable area close to original arcade sizes.
- Full size virtual pinball table with triple screen configuration.
- Dual mic video karaoke with user friendly menu.
- Immersive sound and lighting effects.
Portable:
- Fold up control panel that easily detaches/ attaches to AV and Power.
- CP has onboard computer, wifi, sound and amplification.
- Up to 4-players on an arcade-style Control Panel.
- Play on built-in display if none other available.
- Plug in to an external display such as a living room TV.
- Rechargeable for limited use at locations without power.
« Last Edit: April 17, 2023, 02:32:26 pm by griffindodd »
griffindodd
  • Builds Stuff
I removed the main screen from the sign (a 50" 1080p panel) and put it to the side as I'll be using it again later. I also removed the globe lighting as I want to replace it with something a bit more versatile.
griffindodd
  • Builds Stuff
As the signage and screens will be performing various roles, I wanted the lighting system to be able to adapt too. I'm installing this RGB outdoor lighting system into the existing holes.
griffindodd
  • Builds Stuff
A quick demo of the new lighting.  :laugh:
griffindodd
  • Builds Stuff
The 50" screen will need to be moved back at least 3.5" from the front of the existing frame, it will be 'revealed' when the rig coverts into the pinball format. So I built out the back of the existing structure with deeper framing to house that screen.
griffindodd
  • Builds Stuff
I did the same on the outer frame, although I left an inch or so for it to float out from the wall and take advantage of the ambient light that comes from the smaller inline LEDs on the lighting wires. Stained the outer frame to match the existing finish and blacked out the interior box of the recessed frame.
griffindodd
  • Builds Stuff
Playing with the Visual Pinball software to get an idea of proportions and layout.
griffindodd
  • Builds Stuff
The pinball playfield will slide 'down-and-out' from the sign, so I'm going to need something reasonably stiff and not too heavy to build that structure from. I elected to use 3" deep aluminum 1/8 c-channel with a 1" lip which I purchased from a metals specialty site online.
griffindodd
  • Builds Stuff
I really don't have the correct tools to work with metal, so trying to miter something this size by hand pretty much sucked, but with the help of multiple clamps and a lot of swearing I managed to get the framing for the main playfield and flipper area to work out.
« Last Edit: April 17, 2023, 01:34:07 pm by griffindodd »
griffindodd
  • Builds Stuff
For the main screen I went with an open box SONY X85K 43". It has some nice specs including very low latency, 120hz native frequency and variable refresh rate support. I Know many people go for a 43" ASUS ROG gaming monitor or even an OLED, but I got this screen for under $500, I didn't want to drop double that for one of those options.
Colors on this are fantastic so I'm more than happy for the price.
The casing of the SONY fits snug directly into the C-Channel.  :cheers:
« Last Edit: April 20, 2023, 07:32:01 pm by griffindodd »
griffindodd
  • Builds Stuff
Lots of back n forth between fitting the screen and making sure the measurements are spot on. So far so good though.
griffindodd
  • Builds Stuff
I'm making my own 'lock bar' for this layout as it's much better suited to the build than trying to make a traditional one work or spending money on having a custom one built.
griffindodd
  • Builds Stuff
After doing a little research on the age-old 'how many buttons?' question I decided on the following:
2 Flippers
2 Magnasaves
1 Lockbar 'Fire' button
1 Coin-up
1 Start game
1 Ball Plunge
3 smaller service buttons including escape/back.
griffindodd
  • Builds Stuff
I designed my own Fire button surround, I'll 3D print this with PETG and then hit it with some Rub-n-buff or vinyl to give it a metallic appearance.
bobbyb13
  • Last login:January 16, 2026, 12:49:41 am
Cool stuff.
Did you know the C channel would be perfect fit for the screen already?
That is a score.
How thick is that aluminum stock you are using there?
griffindodd
  • Builds Stuff
Cool stuff.
That is a score.
I based everything I bought on the dimensions given on web sites, I just got super lucky that the fit was so perfect, I couldn't have planned it so well  ;D.  The aluminum is 1/8th stock.
Zebidee
  • Last login:January 07, 2026, 10:22:02 am
Wow, that pinball will be amazing. Following   :applaud:
griffindodd
  • Builds Stuff
3D printing a Fire Plate for the lock bar and while I was at it a Williams plate for my Robotron multi.
  • Last login:Yesterday at 11:01:46 pm
Why is there a brick wall outside your window?
griffindodd
  • Builds Stuff
Terraced back yard.
Finished up the sliding mechanism. For the legs I will have heavy duty locking drawer sliders coming out of the pedestal/base that will house the arcade CP
griffindodd
  • Builds Stuff
Adding the cosmetics and screen to the frame. I will be finishing the control panel in the same stain as the sign frame.
Xiaou2
  • Last login:Yesterday at 06:19:30 pm
  • NOM NOM NOM
When comparing the Donkey Kong photos... the color of the Displays "Whites" look too "Blueish".   There should be a menu option
to change the displays color profile, to a  "Warmer"  color tone  (more reddish hues).   This will make the colors more true to life,
and far less Harsh on the eyes.
 That said, some older display tech, had the older LED technology... which were not capable of producing that Warmer tone.
More modern LEDs now have the capability, of reproducing a much warmer White.   You might be able to replace cooler-LEDs with
warmer LEDs.
thatpurplestuff
Loving your slide idea, very curious to see how this turns out!  This could be a fantastic solution for people wanting a pinball cab but not having the dedicated space for one.
Server rails? good idea they can support a lot of weight.
griffindodd
  • Builds Stuff
Just heavy duty locking drawer rails, I suppose they are probably the same thing.
More general progress. The signage is back on the wall in the new configuration. Just testing the screens and layouts propped up on kitchen stools for now.
bobbyb13
I've never been in the V-pin camp myself but that image is damn impressive.
The physical aspects of the build itself even more so.
griffindodd
  • Builds Stuff
Now we're getting somewhere. All folded up.
griffindodd
  • Builds Stuff
Testing all the wiring, buttons, lights etc.
Get some zip ties for those dangling wires.
griffindodd
  • Builds Stuff
I still have a cabinet to build down there that will also house the fold-out legs/base for the playfield.
Front end is pretty much set up, still have a few graphical tweaks, but that's the fun stuff.
griffindodd
  • Builds Stuff
While toppers are fun and can add to the overall look, I don't like it when they fill the whole upper screen as I find them overpowering. I made some background options that can fill the topper screen and then frame a smaller version when one exists and have a default pinball logo when one doesn't.
« Last Edit: April 28, 2023, 06:27:21 pm by griffindodd »
griffindodd
  • Builds Stuff
I also created a background template for the back glass and DMD areas to give them a little better and more tied together look.
Zebidee
I like the background template with the speakers on the sides - would be good for a music/playlists layout
LTC
  • Last login:January 21, 2026, 10:53:45 am
Really love what you did there.  :applaud:
griffindodd
  • Builds Stuff
That’s better.
Wyo
WOW!
Of course the legend that gives the world the DK in a barrel (and more)…just keeps coming up with unique ideas.
Holy cow man, you’re work is so great!  Glad you’re back…been missing seeing these caliber of builds.  :cheers:
griffindodd
  • Builds Stuff
Lol it's funny how the barrel took off, you see them everywhere now, kinda fun.
I'm revisiting the vertical slider for the 3rd time, still wasn't happy with it as there was a tendency to bind if you didn't bring the playfield down square enough.  I'm going to try using solid rails and sliders designed for CNC work and have a fixed horizontal axis between them that the playfield will hinge around. This should stop the binding and give a much smoother and more reliable action.
griffindodd
  • Builds Stuff
Also I would like to offset the weight of the playfield if I can. I picked a reasonably light TV that still fulfilled the others specs I needed, it's only 22lb (10kg) which is not too bad for a 43" unit, but even with the lightweight aluminum frame the whole thing still has some weight to it and as such requires caution when handling.
I'm going to see if I can integrate a spring balancer and see if it will play well with the rails in the hope of offsetting a decent amount of the playfield weight.
