Author Topic: LEDBlinky not responding to MAME  (Read 1293 times)
mattmillsva
  • Last login:April 16, 2023, 04:28:12 pm
« on: April 16, 2023, 09:13:08 am »
Just got to the point where I can use LEDBLINKY on the new arcade I am building (see attached pic, i am very excited), but this software has been a battle to get working.   I have searched the forums with no luck.
LEDBLINK starts up with no errors and lights up COINOPS control buttons, but it does not light up game buttons as a scroll through mame games games and it does not light up controls with I choose a MAME game.
  - I check the LEDBLINKY debug log and it is running good, just not detecting anything from MAME.
  - used the MAMEOutputTest and it does not show anything happening when I run mame games with the FE or when I run games within mame.exe
step 1 - I installed it and went through the configuration wizard.
step 2 - changed the mame.ini "OSD OUTPUT OPTIONS" to "windows"
step 4 - verified setting in ledblinky
I am using:
OS - Windows 10 (all patches installed)
FE - COINOPS
Emulator - MAME  0.245
LEDBLINKY vs 8.2.1.0 (latest)
Interesting - MAME documents 0.245 does not show "windows" as an option.   only auto, none, console or network.  I tried console and it did not work.
5.1.9 OSD Output Options
-output
Chooses how MAME will handle processing of output notifiers. These are used to connect external outputs
such as the LED lights for the Player 1/2 start buttons on certain arcade machines.
You can choose from: auto, none, console or network
Note that network port is fixed at 8000.
Example:
mame asteroid -output console
led0 = 1
led0 = 0
led0 = 1
led0 = 0
abispac
  • Last login:Yesterday at 12:30:42 am
Re: LEDBlinky not responding to MAME
« Reply #1 on: April 17, 2023, 09:08:06 pm »
No need to post twice.
on your mame cfg file you need to tell it to use windows output, so change it from auto to windows.
Code: [Select]
# OSD OUTPUT OPTIONS
output                    windows
« Last Edit: April 17, 2023, 09:13:35 pm by abispac »
