Author Topic: Groovymame Win10 Switchres Pop Up Error  (Read 7692 times)
trev1976
  • Last login:July 13, 2025, 07:24:36 am
« on: April 11, 2023, 12:21:21 pm »
Hi
Just set up a groovymame win 10 pc and all seems to be working fine apart from an annoying problem.
When I start a game a pop up will appear and say "switchres: error trying to fill monitor range with"
Anyone know how I can get rid of this ?
I followed the "Groovy MAME: Installation and quick configuration (2019 guide)" and all went well until this.
Any help would be great
Sony 14" CRT
VGA to Scart adapter
I5 3470
HD7570
Super Resolutions
psakhis
Re: Groovymame Win10 Switchres Pop Up Error
« Reply #1 on: April 11, 2023, 01:09:14 pm »
Are you using mame.ini updated?
trev1976
« Reply #2 on: April 11, 2023, 03:28:32 pm »
Hi
I'm just using the one
that came in the groovymame folder for mame 0.252.
I think I followed these steps correctly
   2. Create a directory for MAME in the target computer, say, C:\GROOVYMAME, and extract into it the content of Groovy MAME's compressed file. A file with the name mame64.exe should be there. Right-click it, go to Properties, Compatibility and give it Admin. privileges.
3. Make sure the following folders are there: C:\GROOVYMAME\ini and C:\GROOVYMAME\ini\source. The former will be the folder to place per-game (per-machine, in the case of home systems) INI configuration files, while the latter will host per-driver INI configuration files. These INI files will only be needed when we want specific MAME settings for a game or group of games, since they'll get priority over Groovy MAME's main configuration file mame.ini. Remember this.
4. If it's not present after the extraction, create mame.ini: Right-click mame64.exe and click Send to, Desktop (create shortcut). Place this desktop shortcut into GM's directory (paste in C:\GROOVYMAME). Right-click it, go to Properties, Direct access label, and, in the target field add " -cc" -- that is, if it has:
C:\GROOVYMAME\mame64.exe
...it must have:
C:\GROOVYMAME\mame64.exe -cc
Now make it accept the change and double-click this direct access.
5. Make sure a mame.ini file is now in your Groovy MAME directory and delete the direct access you pasted there in the previous step.
« Last Edit: April 11, 2023, 03:36:10 pm by trev1976 »
trev1976
« Reply #3 on: April 11, 2023, 05:38:13 pm »
Hi
Just an update , I decided to use launchbox frontend and once I got it set up I do not get that error anymore , its only when I use the mame built in GUI.
Robbbert
  • Last login:October 26, 2025, 08:39:24 am
« Reply #4 on: April 11, 2023, 10:57:04 pm »
You said 0.252 ?  It had a lot of bugs. Try 0.253 .
Pixeljunkie
  • Last login:August 03, 2023, 03:38:20 pm
« Reply #5 on: April 20, 2023, 03:09:07 pm »
I installed GM 0.253, also keep getting the error (error trying to fill monitor range with)
Radeon HD8940
Super Resolutions (15)
28” CRT TV with vga to scart adapter
How can I get rid of the error ?
  • Last login:Today at 03:17:20 pm
« Reply #6 on: April 20, 2023, 05:20:30 pm »
No error here.
Pixeljunkie
« Reply #7 on: April 23, 2023, 03:02:43 pm »
No error here.
There must be other users who might have experienced the same error ?  :)
Zebidee
  • Last login:Today at 02:34:30 pm
« Reply #8 on: April 23, 2023, 11:34:14 pm »
Just a guess, but Groovymame may be confused about what your monitor can do.
In Vmmaker, last tab "mame", browse to find your Groovymame executable and tick the box "Export settings to Groovymame". Then press OK and you will see a message in the command window "Exporting settings to mame.ini...", which is fairly self-explanatory.
Must be a bad echo in here? I keep hearing my own voice saying that same thing    :blah: :dunno
Like most of us, Calamity is a busy guy, and will normally not provide any more meaningful comment unless you provide a log file :D
Instructions on how to do that are in his signature line, bottom of every post.
« Reply #9 on: April 24, 2023, 01:13:16 pm »
Hi guys,
Sorry I have not time for troubleshooting.
I said I have no error here because I just downloaded GM 253 from my own site, unzipped it on Windows 10, double-clicked on it and it works.
It will spit an error about "Switchres couldn't find a mode that meets your specs" if you don't have the correct modes installed, as it always did.
Pixeljunkie
« Reply #10 on: April 25, 2023, 03:36:50 pm »
It’s just a CRT tv with RGB scart. I did export the settings to GM, but I only installed the super resolutions (15 modes). I followed these instructions to the letter : https://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=1052#p1052
I can get the error to dissappear if I also install the modes generated by the Mame xml, but I only want to use the super resolutions 🙂
I understand that Calamity is a busy guy and I don’t expect an instant reply or anything like that. I work 2 jobs, Fiber optic installer during the day and paramedic in the evening/weekends, so trust me when I say that i’m also a busy guy 😉 Just looking to find out what i’m doing wrong, nothing more
« Last Edit: April 25, 2023, 03:41:07 pm by Pixeljunkie »
« Reply #11 on: April 25, 2023, 05:14:13 pm »
The error reported by the OP was fixed by 253.
You're probably seeing a different error, and unless you provide a log this exchange is worthless.
Well it looks like you still get that error if option monitor is set as "custom" in mame.ini (VMMaker does that) but no actual crt_range is set (all are set as "auto"). Could you check your mame.ini after using VMMaker? There could be a problem there.
EDIT: Nevermind, I could finally reproduce it here.
« Last Edit: April 25, 2023, 05:29:10 pm by Calamity »
Zebidee
« Reply #12 on: April 25, 2023, 09:11:09 pm »
I've gotta ask - when you are busy working and in the thick of things with your hands full of spaghetti-stuff, ever get confused which job you're doing? I have high admiration & respect for paramedics... and fibre installers naturally too, of course :)
Only reason I have any time for this is I'm semi-retired. Even so, not enough time, busy always, days never long enough.
Pixeljunkie
« Reply #13 on: May 03, 2023, 11:18:09 am »
Sorry for the late reply, I didn’t get an email to warn me about new posts. Do you still want me to check my mame.ini or do I need to change anything to verify a fix ?
I see you released an update, nevermind me  :notworthy:
« Last Edit: May 03, 2023, 11:29:03 am by Pixeljunkie »
Pixeljunkie
« Reply #14 on: May 03, 2023, 11:23:25 am »
I also need to apologize to you for not replying, I didn’t get a notification :)
Yes, sometimes I need to take a second to reflect on what i’m doing, but the fact that I have OCD comes in quite handy at times like these. I check and keep double checking so it’s harder to make a mistake (if that makes any sense)
Siris
  • Last login:September 15, 2023, 09:13:08 pm
« Reply #15 on: May 07, 2023, 04:23:51 pm »
Wow, so it wasn't me all along!
This update fixed it for me as well.
Thank you Calamity!
trev1976
« Reply #16 on: August 14, 2023, 04:56:51 pm »
Hi
OP here , I packed this computer away and have only just got it out again , I'm still getting the error and the picture is very narrow on my PVM.
Now sorry for being a PITA but I've totally forgotten what to do with the install , do I just need to run the latest groovymame and update my rom set to the latest to get this fixed ?
buttersoft
  • Last login:Today at 06:07:26 am
  • Is running at 15kHz
« Reply #17 on: August 14, 2023, 07:32:13 pm »
Is the desktop squished like that too? And at what resolution?
trev1976
« Reply #18 on: August 15, 2023, 02:23:04 am »
Hi
Sorry forgot to mention
desktop displays perfect at 640 x 480 , only once I start a game its like this.
buttersoft
« Reply #19 on: August 15, 2023, 02:43:58 am »
Post a log, pls. You can find instructions to do that in Calamity's signature on any post by him.
trev1976
« Reply #20 on: August 15, 2023, 04:20:16 am »
No problem,  when I get in tonight I'll sort that.
buttersoft
« Reply #21 on: August 15, 2023, 07:42:10 am »
oh, wait, i just saw Calamity's response above. I figured you'd already followed that advice, but your response implies not.  You should try the new GroovyMAME, and make sure to leave everything default and not set a custom monitor. As in, pick one of the monitor presets for your PVM - Arcade15 is a good choice.
You probably don't need to update roms unless you run into issues, at least not for testing.
trev1976
« Reply #22 on: August 15, 2023, 10:47:16 am »
OK great , I'll have a play around , can I just overwrite the old groovymame with the new one or do I need to start a new one from scratch following the geedorah guide ?
Sorry its been a while and just need pointing in the right direction
buttersoft
« Reply #23 on: August 15, 2023, 07:30:41 pm »
Starting from scratch is best. Some of the entries in mame.ini will likely be wrong, or missing.
trev1976
« Reply #24 on: August 16, 2023, 02:41:24 am »
Hi
Had a play around with GM and VMM last night , seem to have updated to 0.257 OK and it looks like the pop up message has gone but I'm still getting the squished screen 90% of the time , now and again it's perfect. I've tried , generic,  arcade , arcade extended , 15khz mode lines
Original I set this up on Sony crt TV and didn't have this issue , its only happened since I've moved it over to the PVM.
I'm also curious as to when it boots up it flicks between 16khz & 15khz (does this on all 3 modes ive tried) ? I have atom15 installed,  once the windows logo comes on the screen it's fine so I presume it's the bios splash screen displaying at 16khz , is this normal ?
Anyway hopefully tonight I will workout how to create a log and post it here.
Thanks for your help  :)
trev1976
« Reply #25 on: August 16, 2023, 03:02:48 pm »
probably me being dumb but i seem to be creating a txt file but its blank  :dunno
heres what im doing
Zebidee
« Reply #26 on: August 16, 2023, 06:47:59 pm »
Try changing your directory to E:\Groovymame and running it from there. Change directory like this:
e:
cd e:\groovymame
[edited for correction]
« Last Edit: August 17, 2023, 11:44:40 am by Zebidee »
trev1976
« Reply #27 on: August 18, 2023, 04:30:29 am »
e:
cd e:\groovymame
Hi , thanks
I tried that , still blank , anyway in desperation I was playing with the VMMaker settings and now can't get any display now. .
I've had enough of it now   so I'll pack it away and start fresh when I can be bothered.
Thanks for everyone's help.
trev1976
« Reply #28 on: September 04, 2023, 02:16:04 pm »
ok , went back to this and went a bit crazy spending my whole weeks holiday building 3 groovymame PC's out of spare parts i had , eventually i got them all working but what ive noticed is i get the above fault (squashed image) if i use atom 15 , also i was having a problem with garbled graphics when starting retroarch.
Anyway flashed all my cards back to normal (that was a pain but used this guide)
and all works perfectly now , i use a JPAC and a Extron RGB109xi (Tells me when its safe to switch my TV on) so im not overly bothered about it , just a shame as it was nice to be able to boot up in 15khz.
Ive used atom 15 in the past on XP and all was good but ive had nothing but trouble on Windows 10
« Last Edit: September 04, 2023, 02:19:11 pm by trev1976 »
