Author Topic: Mini PC with integrated ATI RX VEGA compatilibity ?  (Read 2490 times)
archimage
  • Last login:May 23, 2024, 04:32:32 pm
« on: April 05, 2023, 06:58:22 am »
Hi Calamity, are the drivers compatible with this kind of small factor computers with embedded ATI VEGA ?
https://www.amazon.fr/NiPoGi-Windows-AM02-Ordinateur-Business/dp/B0BJ6TC18J/ref=sr_1_10?__mk_fr_FR=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=25CSQ26PLRMC2&keywords=mini+pc+ati+vega&qid=1680692045&s=computers&sprefix=mini+pc+ati+vega%2Ccomputers%2C64&sr=1-10
Do hdmi work correctly for application with Groovymame ?
I'd like to make sure before buying such a device.
Cheers
archimage
Re: Mini PC with integrated ATI RX VEGA compatilibity ?
« Reply #1 on: September 08, 2023, 09:22:40 am »
Up, any update for ATI RX VEGA mobile for Ryzen 7 chips ?
Thanks for your help !
buttersoft
  • Last login:Today at 04:58:45 am
  • Is running at 15kHz
« Reply #2 on: September 08, 2023, 07:08:39 pm »
HMDI can work, under the right conditions, you just need a converter.
The problem is that integrated APU's are always a risk. The general advice is that if you already own one, by all means give it a shot. Just don't go out and buy one expecting it to work with crt_emudriver.
archimage
« Reply #3 on: September 09, 2023, 08:18:51 am »
Hello yes I have tested it and it seems that the current drivers don't support the RX Vega 10 it's not detected.
Is there a workaround for this ?
I have read that groovyarcade may work but I have interest on Windows actually.
Cheers
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #4 on: September 09, 2023, 12:57:13 pm »
What I can tell you for sure, is that it's better to buy a HP EliteDesk Mini with a Ryzen 2200G (not GE) or 2400G, a DP2VGA converter, and it will work just perfect.
PS : I know some french guy from another forum with the same nickname who was also very interested in CRT with a Raspberry, is it you ? If yes, you should remember me ;)
