Author Topic: DIY Pedals - Wiring / Interface Question?  (Read 4012 times)
Fursphere
  • Last login:Today at 04:51:22 pm
« on: April 03, 2023, 05:04:43 pm »
I've got a pair of Sinden lights on my cabinet, and I've got them working with RetroArch and MAME.   I picked up a pair of industrial foot pedals I'd like to get working for games like Time Crisis.
I'm not sure how to go about wiring them up and interfacing them?   I've got an extra IPAC-2 USB controller that I can use  (seems like a waste for just two buttons, but I've already got it so whatever).
Is there any particular keyboard keys I should map them too?  Or just anything, and then just map them in game to "pedal" ?
Feels too simple...
thanks
  • Last login:Today at 03:02:52 pm
Re: DIY Pedals - Wiring / Interface Question?
« Reply #1 on: April 03, 2023, 06:54:17 pm »
To be clear, what electronic components do they use -- microswitches, potentiometers, or optos?
Wiring is easy.
- Wire pedal microswitches the same way as microswitch arcade buttons.
- Wire potentiometers as described here in the wiki.  (You can't do this with an IPac.)
- Wire optos with 5v, ground, Data A, and Data B.  (You can do this with a 2015 or newer IPac.)
Do you have an Arduino like a Pro Micro lying around?
- With the right choice of firmware, it will work with any of the 3 types of pedal components mentioned above.
Assuming that you have microswitch pedals, use keyboard keys that aren't used as MAME defaults. (B, E, H, M, N, etc.)
Feels too simple...
It's not rocket surgery.   ;)   :lol
Fursphere
« Reply #2 on: April 03, 2023, 07:17:54 pm »
Sorry, they are microswitch based.   Have both NC and NO wiring options.  (NO is what I'll be using)
Thanks for the info (and the unused MAME key list).  Very helpful!
Now I just need a small project box.
« Reply #3 on: April 03, 2023, 11:34:58 pm »
You've got it.   ;D
One other possibility to consider:  Is there already an encoder in your setup for joysticks/buttons/admin buttons or are the only controls the two guns?
- If you already have an encoder in your setup, you can either connect the pedals to unused inputs or piggyback the pedals on rarely-used inputs like P1B6 and P2B6.
Glad to assist.   :cheers:
bandicoot
  • Last login:December 18, 2025, 12:30:46 pm
« Reply #4 on: April 04, 2023, 11:26:18 am »
I use this code
https://github.com/crankyoldgit/mame-ipac-emulator
with a pro micro  and edit it to have "B" and "N" key that not interfer emulator
i 've 3d print this
https://www.thingiverse.com/thing:5022017
and buy two pedals from alixpress from here
https://fr.aliexpress.com/item/1005001399341850.html
Fursphere
« Reply #5 on: April 04, 2023, 11:33:55 am »
That 3d printed base is pretty cool.  thanks for the link!
I bought these :  https://www.amazon.com/Switch-250VAC-Nonslip-Momentary-Pedal/dp/B09B3KZ11J?pd_rd_w=BZ2lR&content-id=amzn1.sym.deffa092-2e99-4e9f-b814-0d71c40b24af&pf_rd_p=deffa092-2e99-4e9f-b814-0d71c40b24af&pf_rd_r=P7GP9VN73SZHM5S014FJ&pd_rd_wg=FT1dm&pd_rd_r=133decdc-5c7c-4563-9394-3b8dbe4ea91a&pd_rd_i=B09B3KZ11J&psc=1&ref_=pd_bap_d_grid_rp_0_1_t
They were $10 when I bought them.  But basically the same thing as the Aliexpress ones in function.
Is Time Crisis 5 still locked behind the Teknoparrot patreon only track?
