Author Topic: GroovyMAME vertical game resolution question  (Read 1752 times)
chriszhxi
  • Last login:February 22, 2025, 03:48:08 am
« on: April 01, 2023, 10:26:50 am »
I have a 15/24k dual sync monitor, most vertical games switch to right resolution accordingly, but for Contra which resolution is 280 x 224 (V), it switches to 2560x320p instead of 280p, is this correct? If not, how can I correct it?
makya
  • Last login:January 14, 2026, 05:53:17 am
Re: GroovyMAME vertical game resolution question
« Reply #1 on: April 02, 2023, 04:23:44 pm »
Yes this is normal. 280p requires approx. 300 or 310 lines with blanking. Refresh rate is 60 Hz so let's calculate the required horizontal frequency: 300x60 = 18000 Hz or 18 kHz. It's out the typical range of a 15 kHz or 24 kHz monitor.
chriszhxi
« Reply #2 on: April 02, 2023, 05:29:02 pm »
I see, thanks.
