Author Topic: Is this setup guide from eisdemmodi still relevant?  (Read 2388 times)
sittingduck
  • Last login:July 24, 2025, 05:01:28 pm
« on: March 22, 2023, 05:34:41 am »
Is this GroovyMame setup guide still relevant for a new setup or is it outdated now? Installation and quick configuration (2019 guide): http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=433
Thanks.
« Last Edit: March 22, 2023, 06:20:48 am by sittingduck »
bobbyb13
  • Last login:Today at 03:44:48 am
Re: Is this setup guide from eisdemmodi still relevant?
« Reply #1 on: March 22, 2023, 11:56:15 am »
That was what I used the last time I built a cabinet for that setup and it worked so imagine nothing has changed.
There are a lot of threads here about CRTEmudriver and groovymame.
Make sure you pick the right drivers for your gpu and follow the directions word for word.
You may want to read through this also as the process ia the same even if some of the details have changed slightly.
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=301
buttersoft
  • Last login:Today at 12:19:35 am
  • Is running at 15kHz
« Reply #2 on: March 22, 2023, 06:18:37 pm »
Even if it's not perfect, it's probably the best out there. Come back and ask questions if you have any issues :)
