Author Topic: Roms Groovyarcade 2022  (Read 3193 times)
Diogo
  • Last login:December 18, 2023, 07:29:04 pm
  • Learn a little every day ....
« on: January 30, 2023, 09:13:34 am »
Hi, sorry if this is not the right place to ask this question.
I would like to know for which version of MAME I should download the roms for GroovyArcade 2022.
(Google translator)
GroggyExpulsion
  • Last login:July 15, 2025, 05:39:43 pm
Re: Roms Groovyarcade 2022
« Reply #1 on: January 30, 2023, 02:23:26 pm »
https://gitlab.com/groovyarcade/support/-/wikis/3-Post-Installation-and-Maintenance/3.3-Adding-MAME-ROMs
Discover Which Version of GroovyMAME is Installed
After reading the official MAME documents, you should be aware that your MAME romset should match the version of MAME you are running.  The easiest way to determine GroovyMAME's version is to execute groovymame -help from the terminal.  To do this, you'll first need to navigate to an available terminal by pressing the Ctrl+Alt+F2 key combination.  At the terminal, log in using the username arcade and the password arcade (if you changed the password for the arcade user, provide that updated password instead).  Once you successfully log in, simply type groovyarcade -help followed by pressing the Enter key
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #2 on: January 30, 2023, 02:59:39 pm »
Groovymame is updatable at any time, and always on par with mainline mame. So don't focus too much on a version for your romset, get Something that works for 0.248
insx
  • Last login:August 16, 2025, 06:17:23 pm
  • I dabble in Retropie and virtual pinball
« Reply #3 on: June 13, 2023, 08:49:37 am »
Deleted - I was wrong :)
« Last Edit: June 14, 2023, 06:59:00 am by insx »
