Author Topic: MAME4to8: Auto 4/8 Way Script for Thunderstick TOS GRS restrictor for Hyperspin  (Read 24656 times)
Justin
  • Last login:March 05, 2026, 09:56:05 pm
    • Centipede MAME cabinet
PROJECT MAME4to8
v1.3
-MAME4to8 is now an app!
-No need to compile
-Rewritten to utilize its own INI file for easy configuration.
NOTE:  Antivirus programs tend to think these AutoIT based Apps/Scripts are virus.   I assure you there is no malicious code here.  I included the Source Code so you can see for yourself and compile yourself for peace of mind.
WHAT IS THIS?
For anyone who has a Sanwa joystick with the motorized TOS GRS restrictor plate from Thunderstick,  I have created a nice AutoIt App that if invoked will automatically switch your restrictors according to the MAME game's 4 or 8 way needs.
I have seen integration of this functionality for Retropie and some Frontends like Launch Box, but the solutions were not universal, and I don't own those systems.
I am a HyperSpin avid user, and this script works perfectly with HyperSpin.    It should also work with many other frontends running MAME.
Edit: I now switched to AttractMode front end and it works perfectly with it too.
FILES ARE ATTACHED TO THIS POST
« Last Edit: July 29, 2025, 09:57:08 pm by Justin »
"3 warps to Uranus" -- so I stopped playing!
Justin
VERSION HISTORY
v1.34 02/13/2023
-Fixed a bug that prevented the script for working under newer Hyperspin versions.
v1.3  02/31/2023
-No need to compile
v1.0   02/27/2023
-Initial release
v1.1   02/28/2023
-Added option for auto-detecting COM port.
« Last Edit: February 13, 2023, 04:34:39 pm by Justin »
Justin
Is anyone using this? Looking for feedback or issue reporting. Thanks !
R2TW
  • Last login:April 27, 2024, 06:11:02 pm
Hi Justin is there anyway you could reupload this program download links are no longer working and this is exactly what I'm looking for.
Thanks Rob
  • Last login:Today at 11:51:09 am
Thanks Rob
If not, there's a backup on archive.org.
https://web.archive.org/web/20240322192454/http://vesperworks.com/mame4to8/mame4to8.zip
R2TW
Thank you so much for the Archive link got it working perfectly with Coin-ops Front End within minutes.
Justin
It appears that my hosting site thinks the program has (or is!) a Virus.  So it deletes it as soon as I upload it.   I recall that my antivirus also thought this could be a virus at the time, and so I added it to the exception list.     I know that many times, AV programs think AutoIT Scripts or similar are Virus -  but they are not.
I guess use the archive link for now until I find a solution!
Justin
FILES IS NOW ATTACHED TO ORIGINAL POST!
Justin
Anyone else using this, and has it been working OK for you?
skr
  • Last login:Yesterday at 03:08:25 pm
I will try your app once the restrictors arrive - ordered yesterday :)
I am using Attract-Mode, has this been tested with your app yet?
skr
Guess I can answer my question now - seems to work flawless with Attract-Mode, I have just tested the setup with loading a few 4-way games - thanks for the script!
Justin
Glad it works for you too.  I've switched to attract mode myself and ditched hyperspin.  This code is designed to work with any front end.
