Author Topic: What are the all available 4-8 way* top* switchable joysticks?  (Read 2848 times)
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
« on: January 12, 2023, 10:34:40 am »
Hi all!   I'm back after 15 years.  yikes!
Im looking to redo my MAME Cabinet's control panel.  I currently have a4-8 way switchable joystick (SANWA).
I want a different type than can switch from the top... I see only so far the ultimarc MagStik Plus, but that won't fit my very constrained panel.   Are there any other options that will top switch?
If not, has anyone hacked the SANWA to allow for switching from top?
"3 warps to Uranus" -- so I stopped playing!
  • Last login:Today at 06:30:40 pm
Re: What are the all available 4-8 way* top* switchable joysticks?
« Reply #1 on: January 12, 2023, 01:51:19 pm »
Welcome back!   :cheers:
Have you considered automating the process with Ultimarc ServoStiks?
https://www.ultimarc.com/arcade-controls/joysticks/servostik/
Related thread: http://forum.arcadecontrols.com/index.php/topic,150215.msg1713773.html#msg1713773
Justin
« Reply #2 on: January 12, 2023, 03:21:11 pm »
Thanks!  I'll look.  It seems even larger though!
I also need a small compact 2.25inch trackball and a place that will fabricate my wooden panel to specs lol.   Oh good times!
Zeosstud
  • Last login:February 24, 2026, 05:32:44 pm
« Reply #3 on: January 12, 2023, 05:13:40 pm »
if you got room for a button, you can now switch sanwa joysicks with just a press of one.
https://thunderstickstudio.com/products/tos-grs-4-to-8-way-restrictor-all-in-one-kit
Enjoy!!
Justin
« Reply #4 on: January 12, 2023, 06:55:26 pm »
Enjoy!!
I'll be damned. Wow.   But I think this adds to much height to the assembly and it won't fit my panel.  Ugh!
StefanBurger
  • Last login:October 28, 2025, 10:44:03 pm
« Reply #5 on: January 13, 2023, 03:51:41 pm »
Enjoy!!
On Retropie you can install the script for automated change, based on game selection. So no need for installation of the button at all required.
BR Stefan Burger
Justin
« Reply #6 on: January 13, 2023, 04:02:08 pm »
Thanks Stephan!   I just looked and it seems I may have enough room at the bottom of the joystick to install the hardware.
Do you know how much more height it adds to the assembly under the panel?
Also, I don't know the model of my sanwa. Do you know if this one is compatible?
« Reply #7 on: January 15, 2023, 02:04:42 pm »
I'm using the GRS option and I'm using windows. I've got mine setup to switch automatically, without the button by making a call to the controller via batch before the 4 way games and before the 8 way games. It's a quality product, if you're using a Sanwa.
Justin
« Reply #8 on: January 21, 2023, 06:46:41 pm »
I like it!  Can you do me a huge favor?  Can you measure the total distance from underside of the TOP PLATE of the controller, all the way to the absolute
Bottom of the servo?  I think I may just have enough room for this!
Fursphere
  • Last login:Yesterday at 11:22:58 pm
« Reply #9 on: January 23, 2023, 05:27:03 pm »
I just put an 8-way octagonal restrictor plate in my sanwas.
https://a.co/d/d2U6MsF
