Author Topic: Groovyarcade - Attract Mode in 15khz after update  (Read 5161 times)
GroggyExpulsion
  • Last login:July 15, 2025, 05:39:43 pm
« on: January 05, 2023, 01:48:53 pm »
I have a Tri-Sync Nanao MS2931, after running the system update i now no longer get AttractMode in 31khz
On boot the Bios text displays in 31k, if i drop out into the terminal it is in 15k and if i load groovymame it loads in 31k
Games have no issues autoswitching.. Have looked through all the config files but can't see anything that would effect it. Can confirm monitor is set correctly in the config file
GroggyExpulsion
Re: Groovyarcade - Attract Mode in 15khz after update
« Reply #1 on: January 12, 2023, 10:05:26 pm »
Anyone know how i can get the main UI back to 640 x 480?
Substring
  • Last login:February 06, 2026, 03:00:23 am
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #2 on: January 13, 2023, 06:16:23 pm »
can you give me the output of cat /proc/cmdline ?
GroggyExpulsion
« Reply #3 on: January 16, 2023, 03:35:34 pm »
Sorry for the poor text formatting,
Substring
« Reply #4 on: January 17, 2023, 12:25:08 pm »
Your default resolution is set to 320x240, can't have happened on update. Was like this before. Or you've played with boot resolution in gasetup.
GroggyExpulsion
« Reply #5 on: January 18, 2023, 02:22:35 pm »
Ok fair enough.  But when i run gasetup and select my monitor type - MS-2931 i am unable to change the resolution.  When choosing resolution i get "your selected monitor does not require a resolution change"
Previously choose the MS-2931 monitor would automatically set the UI to 31khz and now it defaults to 15k
Substring
« Reply #6 on: January 18, 2023, 05:03:30 pm »
Do you know which resolution was it running before ?
GroggyExpulsion
« Reply #7 on: January 18, 2023, 08:43:57 pm »
Terminal and UI used to run at 640 x 480
Substring
« Reply #8 on: January 21, 2023, 04:42:26 pm »
can you generate a toucbleshoot archive from gasetup and give me the link ?
GroggyExpulsion
Substring
« Reply #10 on: January 30, 2023, 03:07:51 pm »
So you need to edit the syslinux.cfg boot file and replace video=VGA-1:320x240S with video=VGA-1:640x480S
Do you need further instructions ?
GroggyExpulsion
« Reply #11 on: January 31, 2023, 12:05:51 am »
Thanks mate. I can figure it out from here. Thank you
Substring
« Reply #12 on: January 31, 2023, 12:17:17 pm »
ok, just ask if you feel lost
GroggyExpulsion
« Reply #13 on: January 31, 2023, 02:13:25 pm »
Just one more question. Where would i change the hostname. I have two groovyarcade installs and would like to reference them by hostname
Substring
« Reply #14 on: February 01, 2023, 06:22:53 pm »
Just sudo hostnamectl set-hostname myhostname
GroggyExpulsion
« Reply #15 on: February 02, 2023, 02:42:10 am »
when i open boot/syslinux/syslinux.cfg it does not contain the line to be edited
default arch
timeout 0
prompt 0
#UI vesamenu.c32
menu title Groovy Arcade Linux
label arch
menu label GroovyArcade
linux /vmlinuz-linux-15khz
append root=/dev/disk/by-uuid/1123aef4-437f-48f1-b17d-8746e52367c8 rw quiet rd.udev.log-priority=3 splash mitig>
initrd /initramfs-linux-15khz.img
Substring
« Reply #16 on: February 02, 2023, 04:41:43 pm »
It does contain it, it's at the end of the line starting with append, it's cut in your copy, see that > at the end
GroggyExpulsion
« Reply #17 on: February 05, 2023, 11:35:05 pm »
right you are.. didn't realise how long that line was
Thanks for the patience  ;D
Substring
« Reply #18 on: February 06, 2023, 01:35:33 pm »
you're welcome :)
