Author Topic: Over thinking my control panel layout.  (Read 1402 times)
nadcraker
  • Last login:December 01, 2025, 01:01:55 pm
« on: December 28, 2022, 06:37:23 pm »
I am currently building a MAME cab from a Dynamo cabinet, and I've filled in the old holes on the control panel and it's time to drill new holes. I want to go with this layout from slagcoin:
which is all well and good. But what I am struggling with is where do I actually put this template on the panel? If I draw a line down the middle then I have P1 and P2 space laid out. But where do I position the template within those spaces? I guess all I really need to know is where the joystick goes. Then the template takes care of the rest.
Is there a standard? Like, 2" from the edge and centered between the top and the bottom? Any good rule of thumb?
Getting the panel to this point was a lot of work and I already screwed it up once. I don't want to do it again.
Also...I assume this template will work for IL buttons? Even though it's meant for 30mm sanwa? I just put the center hole in the same spot but use my 1 1/8" hole saw?
  • Last login:Today at 02:27:03 pm
Re: Over thinking my control panel layout.
« Reply #1 on: December 28, 2022, 07:32:15 pm »
You may want to make a test panel or two using cardboard or 1/8" hardboard to check the feel/positioning/spacing of the buttons and check the space between the players (larger players ==> more space between them, controls closer to the sides) before you drill the holes on your metal panel.
Yes.  1-1/8" = 28.575mm so the spacing should be fine.
