Author Topic: MAME can't see USB Encoder / USB Input Device :(  (Read 1953 times)
BazookaJo
  • Last login:December 20, 2022, 03:53:30 pm
    • BazookaJo Paper models
« on: December 01, 2022, 08:07:15 am »
Hi guys - building my own Atari star Wars upright.
Have the GRS yoke, and have 2 Coin Push buttons with microswitches plugged into a zero delay encoder.
PC picks up the encoder as "USB Input Device" but it doesn't seem to appear in any of the controller menus, and I can't seem to map the button presses to any controls.
Anyone know what embarrassingly obvious step I've missed?
Cheers
Joe.
http://www.bazookajo.me.uk/ - home of the Marvin the Martian paper model :)
bollwerk
  • Last login:November 20, 2023, 08:27:52 pm
Re: MAME can't see USB Encoder / USB Input Device :(
« Reply #1 on: December 05, 2022, 07:15:08 pm »
My thought process for troubleshooting -
1) Run MAME -v in command line - the output will show what input devices it detects.
2) Find which one is likely the yoke
3) hard code the yoke to MOUSECODE_1 or something similar
More info - https://docs.mamedev.org/advanced/devicemap.html
« Reply #2 on: December 05, 2022, 11:35:28 pm »
if the yoke shows up as a joystick you need to add the -joystick command line .   If it's a mouse, you guessed it.   -mouse.
  • Last login:Yesterday at 08:00:19 am
« Reply #3 on: December 06, 2022, 08:38:40 am »
These options can be seen and set in the mame.ini file.
BazookaJo
« Reply #4 on: December 14, 2022, 01:30:23 pm »
Cheers guys
Okay - so after a little diddling I can now assign the coin buttons to Coin 1 and Coin 2 via
General Settings -> Input Assignments -> Other Controls   :applaud:
However, the assignments look greyed out and Star Wars does not pick up the buttons  :cry:
any ideas?
BazookaJo
« Reply #5 on: December 14, 2022, 01:51:49 pm »
Ignore that - didn't have the main controller attached so think it was using the buttons as standard joystick inputs which were overriding the coin inputs.  :o
